Develop and rebuild template sensor to python_script
you mean the card_mod style doesn’t work? If not we have to find out how to get it to work (again), style the fold_entity_row header…it did before… see: How to style the fold-entity-row head? - #9 by Mariusthvdb
about the alignment: as said, in my case, all is well (aligned to the left side of the top thumbs, except for the header alignement, which is shifted too far to the right:
yours are all shifted right :wink:
btw, I’ve taken the card out of the top entities card, which allows for one less card_mod too:
type: custom:hui-element
card_type: entities
title: Unavailable Unknown None
show_header_toggle: false
style: |
  ha-card {
    box-shadow: none;
  .card-header {color: var(--primary-color);font-weight: bold;}
 # "#states > div:nth-child(n+1) > fold-entity-row":
 #    "#head > entity-row-maker > hui-section-row":
 #        div.divider {
 #          height: 0px;
 #        div.label {
 #          font-weight: bold;
entities:
  - sensor.uun_ordered
  - entity: script.update_entities_uun
    secondary_info: last-triggered
    action_name: Update
alignment is solved, it was as easy as adding padding: 0 to the top fold… how I could have missed that. Had to adjust the other styles for the left side shift to -8px because of that:
  - type: custom:fold-entity-row
    head:
      type: section
      label: Details
    padding: 0
    entities:
        head:
          type: section
          label: Unknown entities
        padding: 0
        entities:
          - type: custom:hui-markdown-card
            style: |
              ha-card {
                box-shadow: none;
                margin: -16px -16px -16px -8px;
            content: |
              Count: {{state_attr('sensor.uun_ordered','unknown_count')}}
              {{state_attr('sensor.uun_ordered','unknown_entities')}}
for all folds. and makes it looks perfect:
only thing left is to style the fold heads, can’t stand this is so difficult to find out…
Hi Marius,
Would you happen to have this issue as well? Each time I open a new HA instance or that I refresh, I’m getting this…
Refreshing 2-3 times, sometimes needs to clear cache (Ctrl+F5), but it eventually comes back to working good
That’s an old issue indeed. From the top of my head you can solve that using the hui-element custom card by Thomas loven and then add the markdown card in that
Explanation:
You can also use the card-preloader to fix this.
You were right… Here’s for posterity
Use this
- type: custom:hui-element
  card_type: markdown
Instead of:
Thanks :slight_smile:
card-preloaded caused issues still, or maybe put differently, didnt solve it all.
added to that is seemed to do so in a ‘hacky’ way, and not always, seemed a bit flaky. While hue-element solved all red cards, never seen a red card since using that. And so easy.
see this post from Thomas why probably: https://github.com/home-assistant/frontend/issues/4984#issuecomment-610781709
