Strange. If you go to the services dev tool, is device_tracker.see still listed in the dropdown there? (If you don’t mind upgrading again to check that)
Also, are you using any other device_tracker components, other than ones directly updated via the service call?
I have two device_tracker components, both updated with device_tracker.see and no other device_tracker component. In version 0.93.2 device_tracker.see is always available and starting version 0.94.X you have to use a device_tracker component to use device_tracker.see.
I setup a device_tracker on my router without using the results…
FYI, after upgrading from 0.94 to 0.96, I started running into issues with my device_trackers not retaining state on restart once again.
Rather than try to figure out another workaround, this time I opted to switch to the MQTT Device Tracker. I had just spun up MQTT for some other purposes, so since I was already using it, I figured it would be pretty painless to switch to it for my presence detection, and it was. And if you send your messages with the retain flag, it will persist through restart without issue.
I’m going to put together a longer blog post on what specifically I’m doing for presence detection now, but it’s a pretty clean swap if you’re already using device_tracker.see and are interested in switching from to the MQTT Device Tracker (or JSON MQTT Device Tracker if you’re wanting to send latitude/longitude/device battery data).
This is for a virtual presence device_tracker created using device_tracker.see. I use it for guest presence when my z-wave door lock is unlocked by certain codes assigned to guests. My automation then marks the guest as home, but this resets to away if I happen to restart HA sometime during the day. I have to remember to mark them home if they are still home.
Why not avoid device_tracker and make an input boolean? That will store states on restart. Then build a binary_sensor with device_class: presence set on it.
