Strange…
It works fine for me…
that is why i go hmmmm
and it was also the reason for
no offence taken btw…
According to Group - Home Assistant (home-assistant.io)
view is not a variable.
Try and remove/comment that line.
that was it.
now i will rewrite the automation itself…
so i ended up with:
groups.yaml
person_trackers:
entities:
- person.tina_andersen
- person.bo_herrmannsen_5
the automation itself:
alias: Tænd lys når hjemme
description: ''
- platform: state
entity_id: group.person_trackers
to: home
condition:
- condition: sun
before: sunrise
after: sunset
- type: turn_on
device_id: ****
entity_id: light.kitchen_1
domain: light
brightness_pct: 60
- type: turn_on
device_id: ****
entity_id: light.kitchen_2
domain: light
brightness_pct: 60
mode: single
my lights are grouped allready in phoscon hence that i work directly with lights, or so it would seem
Should work. But since they are device trackers based on GPS then you could get lag.
You could add router device trackers to the group that detects if you connect to wifi, that could be faster.
If you have the companion app installed you can use the wifi state which probably is the fastest to update of them all.
we both have the app installed, so if the lag is to big we could go that route
Yes if you can connect to the wifi outside the apartment.
Usually you can but it has to be a few meters to give some effect.
If you go that route you just add the sensor for wifi ssid in the app and look for state change = wifi name as another trigger to your automation.
But GPS lag can be quite significant.
I have had less lag using the companion apps device tracker than Google maps tracker.
But can’t say for sure which is better.
I recently got a new phone and it made a significant change to the better.
Now I get a new update every ~100 m when driving
both our phones are also new, the old ones was worn out and the plastic started to crack and fall apart
so i think that with gps and the area being so big by the time we get to our door it will be fine.
if not, wifi is barely ok at the garage, but by the time we get to the staircase its ok
so only time can tell if i need to add it as a trigger
There is no harm in adding it. All triggers are “or”, so whatever happens first will trigger the automation.
easy enough
but thinking of it, when at mom-in-law the ssid is the same, but then we are not home
will have to look at what the other sensors are
ahh wifi_bssid
will try that one instead as that is Unique
You can also log in to the router and change the name.
But that will affect all wireless devices you have.
yep, more trouble that it’s worth
i wanted to do the same when leaving…
ie i made a dublicate and then said when not_home switch off lights
using the wifi will make that happen a lot faster, but given that when driving away it might connect and disconnect from wifi a few times can i add a delay before new changes are considered a trigger?
is what i have in mind,
now also thinking that if one is home and the other needs to go and pick up a parcel
with the current setup would that not switch off the lights?
It sucks… But you only do it once.
I would create two device trackers that is controlled by automations.
The device trackers only need home/not home state so it’s not that hard.
Example:
Template device_tracker - Feature Requests - Home Assistant Community (home-assistant.io)
But in your case the trigger has to be wifi bssid.
Then you can add these two device trackers to your group and all logic will be maintained by the group (and work as you expect).
I actually can’t find where I created a device tracker.
The only place I can see anything regarding one of the trackers I have is in the known_devices.yaml.
kraftan:
picture: /local/kraftan3.png
icon: mdi:golf-cart
track: true
This is the device tracker that is updated when her phone disconnects from BT in the car so that it “parks” her car on a map.
Yes… it’s needed.
i can only trigger once? or what do you mean?
and by 2 device trackers i assume you mean one with bssid and the other home/not_home?
You only do the configuration once. It’s a lot of work but since you only do it once it’s just a matter of getting it done.
One for you and one for her.
From the linked thread:
- data_template:
dev_id: richard
location_name: >
{% if is_state('binary_sensor.richard', 'on') -%}
home
{%- else -%}
not_home
{%- endif %}
As you can see the location is updated with home or not home
Yours should be something like:
- data_template:
dev_id: richard
location_name: >
{% if state('sensor.sm_a515f_wifi_forbindelse', 'YOUR WIFI BSSID') -%}
home
{%- else -%}
not_home
{%- endif %}
ahh now i get it
so i create one automation for me and one for her
and in each i just put in:
- data_template:
dev_id: richard
location_name: >
home
{%- else -%}
not_home
{%- endif %}
of course i need to update the names in them so they match my setup… ie dev_id needs to change from richard to our names
