I’ve recently setup a ESP32 to run ESPHome as a bluetooth proxy. I used the online portal to flash the ESP32. The ESP32 was detected by my HA install automatically and subsequently detected my Xiaomi LYWSDCGQ which is showing up under the Xiaomi BLE integration.
Now after a few days the LYWSDCGQ is showing as unavailable, and I have no idea how to get it back. Ive tried power cycling the ESP32 and the LYWSDCGQ without success. Any ideas on how to get it back?
I’ve removed all of the devices from HA and started again, so far so good.
I’m running version 2022.8.3 of the ESPHome addon in HA, but the ESP32 is reporting version 2022.9.0-dev. Is it safe to have the HA addon adopt the ESP32?
If you flashed your ESPHome proxy before 7:00AM UTC on Tuesday, December 13, 2022, please flash again as it should improve the connection times.
Please use the web flash tool below or ESPHome addon 2022.12.0b5 or later as the main line ESPHome addon does not yet have the connection time improvements or aarch64 flashing fix: https://esphome.github.io/bluetooth-proxies/
If you use the ESPHome addon you MUST connect the device via serial to flash it or you will not see the performance improvements with active connections.
