So midnight again in the Netherlands and it is not working. Same issue open the gate nothing. Delete the sun part and it is working.
I would try with this,
- condition: state
entity_id: sun.sun
state: 'below_horizon'
This is what I use, I haven’t used condition: sun before, but according to the homeassisant docs it is setup right. But, give it a try like above and see where that leads you.
Couple of things;
Do you get anything in your log when you trigger after midnight?
I have added the sun integration to my config, but I’m not sure that is needed for basic sunset triggering or maybe it’s enabled by default now a days.
In the Netherlands sunset is always before midnight so there is no need to add after: sunset
@TinyDoT I have changed the lines and now fingers crossed it will work.
@Sjee yes I have the sun integration inside my config, lights turn on after sunset. I will see in my log file what is what.
Okay small update. After the new lines of TinyDoT Home Assistant did not start. Because of no time at 0:00 I did not check the setup result all lights were on this morning. Now I have deleted the lines and all is working except the open gate light part.
23 augustus 2019
22:27
Home Assistant stopped
22:26
Qubino (Goap) ZMNHDD1 Flush Dimmer Power Management changed to 254
22:26
Qubino (Goap) ZMNHDD1 Flush Dimmer SourceNodeId changed to 0
22:26
Qubino (Goap) ZMNHDD1 Flush Dimmer Alarm Level changed to 0
22:26
Qubino (Goap) ZMNHDD1 Flush Dimmer Alarm Type changed to 0
22:26
Qubino (Goap) ZMNHDD1 Flush Dimmer Exporting changed to False
22:22
22:22
22:22
22:22
22:22
22:21
Hek changed to open
22:13
22:13
22:13
22:13
22:13
22:00
22:00
22:00
22:00
22:00
22:00
Guesthouse dimmen om 0:00 has been triggered
21:59
21:59
21:59
21:59
21:59
21:51
21:27
21:27
21:27
21:27
21:27
21:07
21:07
21:07
21:07
21:07
21:00
Hek changed to closed
20:58
20:58
20:58
20:58
20:58
20:47
20:47
20:47
20:47
20:47
20:47
GuestHouse Dimmer turned on
20:47
Voordeur lamp turned on
20:47
Lantaarnpaal turned on
20:47
Hekverlichting turned on
20:47
Garage deuren turned on
20:47
Zon onder has been triggered
20:47
Sun has set
19:46
BR Arnhem (6275) changed to cloudy
19:36
BR Arnhem (6275) changed to partlycloudy
18:26
18:05
BR Arnhem (6275) changed to sunny
17:56
16:51
Hek changed to open
14:55
10:29
Hek changed to open
9:46
8:05
Hal verlichting turned off
8:05
Hal verlichting turned on
8:04
8:04
8:04
Hekverlichting Dimmer turned off
8:03
Hek changed to open
7:34
7:31
yr Symbol changed to 3
7:24
BR Arnhem (6275) changed to fog
7:04
6:54
6:33
6:33
6:33
6:33
6:33
6:33
6:33
6:33
6:33
6:33
6:33
GuestHouse Dimmer turned off
6:33
Voordeur lamp turned off
6:33
Lantaarnpaal turned off
6:33
Hekverlichting turned off
6:33
Zon op has been triggered
6:33
Sun has risen
6:20
6:20
6:20
6:20
6:20
5:34
5:31
yr Symbol changed to 2
5:14
5:04
3:34
2:58
2:58
2:58
2:58
2:58
2:34
2:13
1:34
1:34
1:34
1:34
1:34
0:53
0:44
0:23
0:14
0:04
0:04
0:04
0:04
0:04
0:04
0:02
Hek changed to open
0:00
Garage deuren turned off
0:00
0:00
Hek dimmen om 0:00 has been triggered
@RemcovanKuilenburg can you post your code for me to see and I do believe we need to change
after: 0:00 to after: ‘00:00:00’
We will get this.
Hi TinyDoT. Yes we will nail this.
- id: '1566418818385'
alias: GoGoGate open licht aan
- entity_id: cover.hek
platform: state
to: "open"
condition:
condition: and
conditions:
- condition: time
after: 00:00:00
- condition: sun
after: sunset
before: sunrise
- service: scene.turn_on
entity_id: scene.garden_lights_bright
- service: switch.turn_on
entity_id: switch.qubino_goap_zmnhbdx_flush_2_relays_switch
- id: '1566423130786'
alias: GoGoGate dicht licht uit
platform: state
to: "closed"
condition:
condition: and
conditions:
- condition: time
after: 00:00:00
- condition: sun
after: sunset
before: sunrise
entity_id: scene.garden_lights_dim
- delay:
minutes: 1
- service: switch.turn_off
This is now how I have entered all. Changed the 0:00 to 00:00:00 and now the UI is started. So I have to wait 30 min until midnight.
No trigger when opening the gate.
#### 25 augustus 2019
0:10
[Hek](http://192.168.1.21:8123/logbook#) changed to open
0:09
[Hek](http://192.168.1.21:8123/logbook#) changed to closed
0:07
0:00
[Moon](http://192.168.1.21:8123/logbook#) changed to waning_crescent
0:00
[Qubino (Goap) ZMNHDD1 Flush Dimmer Power Management](http://192.168.1.21:8123/logbook#) changed to 254
0:00
[Qubino (Goap) ZMNHDD1 Flush Dimmer SourceNodeId](http://192.168.1.21:8123/logbook#) changed to 0
0:00
[Qubino (Goap) ZMNHDD1 Flush Dimmer Alarm Level](http://192.168.1.21:8123/logbook#) changed to 0
0:00
[Qubino (Goap) ZMNHDD1 Flush Dimmer Alarm Type](http://192.168.1.21:8123/logbook#) changed to 0
0:00
[Qubino (Goap) ZMNHDD1 Flush Dimmer Exporting](http://192.168.1.21:8123/logbook#) changed to False
0:00
[Garage deuren](http://192.168.1.21:8123/logbook#) turned off
0:00
[Hek dimmen om 0:00](http://192.168.1.21:8123/logbook#) has been triggered
0:00
[0:00](http://192.168.1.21:8123/logbook#) has been triggered
I made a couple of small changes to the code:
platform: state
to: "open"
condition:
condition: and
conditions:
- condition: time
after: '00:00:00'
- condition: sun
after: sunset
before: sunrise
platform: state
to: "closed"
condition:
condition: and
conditions:
- condition: time
after: '00:00:00'
- condition: sun
after: sunset
before: sunrise
- delay:
minutes: 1
One other thing to check, is to make sure your cover.hek is using open and closed for its state instead of on and off. Change the time to see if it works now if you are still up. Also, you may need to remove the " " from around open and closed.
This is not required. Conditions are logic AND by default.
@sparkydave, thanks that is good to know.
You need to remove the after: sunset
condition. Following the conditions docs after sunset is only valid untill midnight, after midnight is a new day so the sun did not set yet.
And again thanks for the updates. I have changed into the last one TinyDoT sent and now my GoGoGate is not visible in the UI. So I think no connection. Will try a reboot again.
Working again. Connection was not okay and did a reset of the GoGoGate unit. Now all fine. Just have to wait until 0:00
Yes it is and found this
21:18
I see in your lines that you use GoGoGate as alias. When I see the integration part they say GoGoGate2. Is that the reason?
# Example configuration.yaml entry cover: - platform: gogogate2 username: [[email protected]](mailto:[email protected]) password: password ip_address: 192.168.1.200
I think we should break this down. I would take the above automation and take out the conditions and see if the action is performed when you open the gate and close the gate. Through the different versions of Homeassitant I have come across time when you need to use " "s or ’ 's around your state item. So I would try the automation with them and with out them. Once you know with version of the automation works then I would put the conditions back in. And, from what @sparkydave said you do not need the “condition: and” statement. @sjee has a good point as well, I think the only condition you would need is after: ‘00:00:00’, but on the other hand you might want to leave the before: sunrise.
This should get us closer to what you want. Also, the alias is just a reference, if you look at your automations on the frontend you will see that is what that automation is called.
When I clear all conditions the trigger works. The garage lights turn on and the fence lights go from dim to full. Reverse also works. The fence lights go to dim again and with delay of 1 min the garage lights turn off.
Version running is 0.97.2
