Direct Flic BUTTON via Flic Hub MQTT integration - Cloudless
I was using the Flic hub SDK to trigger automations with webhooks (thanks to here and there), but using MQTT should be even better, thank you !
But I can’t get it connected with my MQTT. Could you tell exactly what to change in the Main.js file ?
I just changed variable “server” with the name of my MQTT broker “core-mosquitto”, but actually I don’t really know what I’m doing here…
