I believe I’ve followed the directions, but I’m getting this error when I attempt to run the MQTT module on my flic hub:
'Error' event
Error: Crashed
at [anon] (root/MQTT/main.js:230) preventsyield
This isn’t a particularly helpful error message since line 230 is just the error handling function. I modified the main.js values as such:
var server = "192.168.0.15";
var server_options = {
//"username": "",
//"password": "",
"port": 1883,
var hatopic = "homeassistant";
var flictopic = "flic";
var mqtt = require("./mqtt").create(server, server_options);
Does this look right? I don’t think I have a username/password on my MQTT broker and it is running on my HA at port 1883.
Update: I made a tiny modification to get the error message from the client.
mqtt.on('error', function (err) {
console.log('error', err);
setTimeout(function () {
throw new Error("Crashed")
}, 1000);
This got me:
Connection refused, NOT_AUTHORIZED.
So after poking around some more I realized I needed to enter my HOME ASSISTANT username and password!
Newbie here. For the life of me can’t get this to work. Any help much appreciated. Followed all the step diligently and stuck with the below error which I see some other users are also facing.
‘Error’ event
Error: Crashed
Sorry my priorities are elsewhere right now. If someone has a fix and wants to submit a merge request, I’m happy to do that. Just have no time to debug anything right now.
Actually, I think that fork mentioned above might be the way to go! It looks like @asosnovsky has done a full refactor and blows my early attempt out of the water.
Any chance anyone has and idea of increasing bluetooth range of the hub using an ESP32?
Also, if we use Flicd add-on, can we directly connect it with out the hub and in that case take advantage of using the ESP32 as a Bluetooth proxy to extend range?
The integration did scan most of my buttons (I guess only the ones who had remaining battery life).
Which is why I did change the battery in a button which is currently not available in HASS → MQTT.
As far as I understand the manual (Flic - Home Assistant) I have to start the discovery mode through the configuration.yaml file… but I don’t know exactly how.
My config.yaml file currently shows the following data:
# Loads default set of integrations. Do not remove.
default_config:
recorder:
db_url: mysql://homeassistant:xxxxxxx@core-mariadb/homeassistant?charset=utf8mb4
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
Do I have to add:
binary_sensor:
- platform: flic
- discovery: true
and restart the config.yaml?
Because addind those 3 lines of code gives me a context menu (auto completion menu) with which I don’t know what else to do…
And a small additional question:
As far as I understand one can use the following click-types: click, hold and double… click and hold work just fine… only double does not seem to work.
Maybe someone knows how to resolve that?
I tried this fork but it seems to poll a lot more and create entities that switches between unavailable and available every few seconds. I therefore reverted back to the original ingo fork since I do not use IR anyway.
Still super new to HA and MQTT but trying to set up my Flic to be controlled by a button within HA. I have created a script (yaml below) to try and mimic what I can see when the flic button is clicked. I can see the statuses of the “state” and “action” entities change but the light doesn’t turn on or off at all.
Basically, I’m trying to turn on a light via the flic hub by toggling a button card within HA. Let me know if my use case doesn’t make sense and I can elaborate.
I just used the fork from asosnovsky/flic2hass and it works which is awesome so a big thank you to everyone. The only issue was that I had to create a user and password in the Mosquitto broker config under Settings>Add-ons>Mosquitto Configuration and add that to ./main.js because my Flic Hub was initially getting connection errors.
I can see my Flic buttons in Home Assistant and my automation responds to a Flic button press, however, right away the app on the Flic Hub crashes with stack overflow:
btnc|INFO| is up
ir|INFO| starting...
ir|INFO| is up
root|INFO| all services up!
InternalError: stack overflow
at apply (native)
at emit (core.js:566)
at <anonymous> (root/MQTT/lib.js:933)
at apply (native)
at apply (native)
Here’s the relevant part of lib.js:933
// Get the data for this packet
var pData = data.slice(1 + dLen.lenBy, pLen);
// more than one packet? re-emit it so we handle it later
if (data.length > pLen) {
this.client.emit("data", data.slice(pLen, data.length)); // line 933
Perhaps the client object is undefined, but I have not tried to debug the code, but if you’ve seen this or have a fix please share. Thank you.
UPDATE: there is an unmerged pull request in GitHub that someone left for this
> // Avoid an infinite data emit loop
> if (pData.length < 1) {
> this.partData = data;
> return;
I too cannot use the new fork - it crashes often and it has the same issue as the original fork which caused me to have to modify the code.
I had to add a sleep function and include it in the code before it flips back to normal from any action.
I have no idea how any of you are using these as-is because the status of the sensors reverts back to normal so quickly that unless I put in that sleep my automations don’t work at all.
The author of this new version also disabled issues. So there is that…
Hi, I was able to set up the SDK but then after it starts, about 3 min in it crashes every time. below are the logs . it even register the button once i click them even after it crashes
Thank you so much for providing this integration that uses Java to let a Flic hub talk to HA by means of MQTT. I have just started learning about HA within the past week, so there is a lot that I don’t know. I tried the Flic integration and as far as I can see it’s sort of working for me but mostly not working. I carried out all of the steps. I went into my Flick Hub Studio and created the new module MQTT. I edited the main.js file to add the host which is my HA controller. I created lib.js and it contains your entire body of code from earlier today (May 7, 2025). I went around and pressed all three of my Flic buttons.
I then went into HA and looked at my MQTT integration, and previously it had zero devices. Now I have four devices:
* my first Flic button with a model of "v2_white"
* my second Flic button with a model of "v2_white"
* my third Flic button with a model of "v2_white"
*a fourth device called "IR" with a model of "FlicHubIR0"
So it seems very clear that the Flic hub has registered with the MQTT server and has revealed the names and types of these four devices to the MQTT server. But as far as I can see, the “button” devices don’t actually work. For my first Flic button, everything about it is “unavailable”:
Just wanted to say thanks for this post! I’ve been using the flicd add-on without the hub by pschmidt, and it recently broke when updating HA. It also used to require frequent re-connection of the buttons. Set this up last night, the most difficult part was the glitchy flic hub SDK not saving, and doing weird things. But all up and running now. So grateful! The buttons work so much better with the Hub!
Great find! This one seems to move the heavy-lifting logic to Home Assistant instead of relying on the flaky hub Javascript engine. Nice, it installs easily as a HACS module, too.
I had pretty much abandoned my Flic buttons, I’ll give them another shot now.
