The “wait for idle” step doesn’t progress. Is this still working for others?
THis works pretty well for a single speaker but not when broadcasting to a group.
alias: Disable GA chime test
sequence:
- service: media_player.volume_set
volume_level: 0.005
entity_id:
- media_player.downstairs_speakers
- service: tts.google_cloud_say
entity_id: media_player.downstairs_speakers
message: helloooooo there. This is a test of the broadcast.
volume_level: 0.3
mode: single
Actually, it may be because of the lawsuit with Sonus and this:
This does though. I now mirror my google speaker groups into HA groups (annoying but they don’t change much) and use those to drive the volume changes. Works most of the time. maybe 90%.
alias: TTS No Interrupt
sequence:
volume_level: 0.001
data_template:
entity_id: |
{{ expand(target)| map(attribute='entity_id') | join(', ') }}
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 300
message: |
{{message|default('Test Message',true) }}
data_template:
entity_id: |
{{target.replace('group.','media_player.')}}
volume_level: |
{{ volume | default('0.5') }}
data_template:
entity_id: |
mode: parallel
fields:
message:
description: Message to send
example: This is a message
description: The group/entity to broadcast to
example: group.downstairs_speakers
volume:
description: Specify target volume
example: 0.5
Hi @keithcroshaw,
Where you able to disable chime using a node in node-red? If you did could you share how you did it?
Remind me.
It didn’t really work. Often it would fail to turn the volume back up before TTS. That was a while ago. Used to it now.
FYI the original didn’t work for me as it still made the “wakeup” chime sound after the choose action. I had to add 1 second long delay after the second mute in the sequence and then it works (you could still hear the chime sound very little when waiting just 800ms).
alias: Prepare speaker without sound
sequence:
- choose:
- conditions:
- condition: state
entity_id: media_player.nestmini5073
state: "off"
sequence:
- service: media_player.volume_mute
is_volume_muted: true
- service: media_player.turn_on
data: {}
- wait_template: "{{ is_state('media_player.nestmini5073', 'idle') }}"
- conditions:
- condition: state
state: idle
sequence:
is_volume_muted: false
default: []
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
- service: media_player.volume_set # you can remove this one to keep the previous volume
volume_level: 0.5
mode: single
Could you help me to apply thoses scripts ?
How proceed?
I created an automation to launch youtube river and birds sings when movement is detected in my toilets.
The action is
service: media_player.play_media
entity_id: media_player.ytube_music_player
media_content_id: zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
media_content_type: playlist
metadata:
title: SDB
thumbnail: >-
https://lh3.googleusercontent.com/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
media_class: playlist
children_media_class: track
navigateIds:
- media_content_type: library_playlists
media_content_id: ""
- media_content_type: playlist
How can i remove the litle google chim ?
Thanks !
I updated the script originally shared to include friendly fields when using the script in your automations.
- Copy the script below.
- Create a new script in HA.
- Go to the … menu and select Edit in YAML.
- Select everything and Paste the script you copied from below.
- Use the “Cast Media…” script as an action in your automations.
alias: Cast Media with no Chime 🔕
sequence:
- choose:
- conditions:
- condition: template
value_template: "{{ is_state(media_file.entity_id,'off') }}"
sequence:
entity_id: "{{ media_file.entity_id }}"
volume_level: 0
data: {}
- if:
value_template: "{{ not is_state(media_file.entity_id, 'idle') }}"
then:
- wait_template: "{{ is_state(media_file.entity_id, 'idle') }}"
timeout: "0:00:05"
- conditions:
value_template: "{{ is_state(media_file.entity_id, 'idle') }}"
sequence: []
volume_level: "{{ volume }}"
- service: media_player.play_media
media_content_id: "{{ media_file.media_content_id }}"
media_content_type: "{{ media_file.media_content_type }}"
mode: single
fields:
media_file:
selector:
media: {}
required: true
volume:
selector:
number:
min: 0
max: 1
step: 0.05
default: 0.5
required: true
Hi @djahren
I tried your script, but I get an error:
sequence:
- choose:
- conditions:
sequence:
volume_level: 0
data: {}
- if:
then:
timeout: "0:00:05"
- conditions:
sequence: []
mode: single
fields:
media_file:
selector:
media: {}
required: true
default:
media_content_id: media-source://tts/tts.google_en_com?message=This+is+a+test&language=en
media_content_type: provider
metadata:
title: This is a test
thumbnail: https://brands.home-assistant.io/_/tts/logo.png
media_class: app
children_media_class: null
navigateIds:
- media_content_type: app
- media_content_type: provider
media_content_id: >-
volume:
selector:
number:
min: 0
max: 1
step: 0.05
default: 0.5
required: false
It looks like you probably didn’t use the script as an action in an automation. When you do that, you select the target and the media file. I Tested it and it works ok, I still hear a little tone if the speaker was idle. There is a little delay but not too bad. I wish there was a way to just directly play an audio file using the Google Assistant SDK instead of casting.
I know this is an older thread, but I’m wondering if anyone has figured out how to mute the beep from the Nest Mini when the volume gets adjusted. OP’s script for muting the power-on chime worked perfectly, but I’m still left with the volume blip.
Hello! Thanks for the script. I put in a silent mp3 and it plays, but you can still hear a volume adjustment sound, a small beep sound. How else could this be turned off?
As far as I know, this is native to the Nest mini speaker, as it’s the same sound when manually adjusting the volume using the touch buttons on the speaker.
If there were any hope of disabling that, I’d look at native solutions in the speaker to do so, or search for info regarding the Nest mini speaker, completely outside of Home Assistant. At a glance from the speaker settings itself, I’m not able to find anything. But I’d be curious to know if someone else is able to dig up any info on this.
I wasn’t sure of the issue at first but taking another look at this I think I may know what’s going on. It appears as if you are filling out the script from the script edit page. The script is meant to be used within other automations or scripts and the fields are filled out within the automation. Doing so should ensure the fields are filled out correctly.
I did notice a bug which I’ve edited. volume: required should be set to true, not false, as all fields need to be filled out.
This one seems to work for me using a Google Home Display.
Thanks, it was driving me crazy as I’m also using Chime_TTS from HACS which creates a nice chime with the talking immediately after the chime happens. I used to have 2 chimes happening with a delay between the two chimes. Now they are gone.
Does it work with the volume feature in Chime TTS? Does announce work for you? On my Google display music never resumes.
I wouldn’t know since I never use my google display to play music since it’s very low quality speakers. I prefer my sonos for playing music. Google Home is only for announcements. Sorry
Super old thread, but I seem to have found a workable solution.
I haven’t used my GH Mini for about 6 years, but pulled it out for an extra Halloween sound source. The start up chime is a non-starter and normally I would turn to Alexa for this task, but the connection is giving me trouble so I started down this path instead.
While turning the volume down and back up is workable (Mute/Unmute isn’t working properly for me), the blip when the volume is turned back up spoils the effect.
My solution was to create a automation that plays a wave file that is just 0.3 seconds of silence every 59 seconds. This only plays the chime once when the automation first triggers and then silently keeps the GH Mini ready to play my sound files, with no chime or blip proceeding them.
Hope someone finds this useful. Thanks to all for the ideas from this thread.
Thanks for the idea! I basically did the same thing, opened up a super old GH Mini for spooky Halloween sounds. I’m sending a silent 500ms mp3 every 2 minutes, as long as another sound is not playing. If a sound is playing, I delay by 5 seconds and then send the silent mp3. Exactly what I needed. Thanks again!
