Depending on which flavor of Home Assistant you have, the root directory may be different than /config. The general idea is to create a www directory within whatever is your configuration directory. I created yet another directory withinwww called card-mod but that’s optional and only because I want the card-mod plugin to be clearly separate from other plugins.
Once that’s done, there’s one more simple step.
Go to: Configuration > Lovelace Dashboards > Resources
If you don’t see that menu option, follow the instructions in the “manual technique” link above.
Click the Add Resource button and enter the path to the card-mod.js file. Be advised that /config/www is understood to be /local. Based on the path shown above, here’s what I entered in the URL field: /local/card-mod/card-mod.js?v=2.0.3
The version number tacked onto the end of the URL isn’t essential. It’s a convenience to help you remember what you installed. Whenever you replace card-mod.js with a newer version, you can update the URL’s ?v=X.X.X to reflect the new version number. This also has the benefit of instructing the browser that the plugin’s code is sourced from a “newer” URL.
At this point, you’re done with the installation of card-mod. Refresh your browser (Ctrl+F5) so that it incorporates card-mod.
If you have already edited your Alarm Panel Card with the changes you posted (specifically the style option) the card should display without a keypad (like in the screenshot I posted).
Good post.
I’m with the same situation, I used your code and it’s ok for state if I work on the other two keypads (linked to partitions).
If I try to insert alarm from the new keypad the partitions state not changes.
The entity_ids are ok…
My apologies but I don’t understand what you mean by “insert alarm”. Do you mean that when you try to set the state of alarm_control_panel.master_alarm_panel to arm_home or arm_away it fails?
