Disconnected: Did not receive auth message within 10 seconds
I have the same problem as well
For anyone else using AppDaemon and docker-compose, the current docker-compose looks like this:
# docker-compose.yaml
version: '3.8'
services:
  appdaemon:
    container_name: appdaemon
    image: acockburn/appdaemon:latest
    restart: unless-stopped
    volumes:
      - /etc/localtime:/etc/localtime:ro
      - /opt/homeassistant/config/appdaemon:/conf # Set which local directory will contain all your app daemon configuration
    ports:
      - "${PORT_APP_DAEMON}:${PORT_APP_DAEMON}"
    environment:
      - TZ=${TZ}
      - HA_URL=http://${HA_IP}:${PORT_HA}
      - HA_TOKEN=${HA_APPDAEMON_KEY}
      - DASH_URL=http://${HA_IP}:${PORT_APP_DAEMON}
    depends_on:
      - homeassistant
    labels:
      autoheal: "true"
    # this section is completely optional
    healthcheck:
      test: curl -fSs http://127.0.0.1:${PORT_APP_DAEMON} || exit 1
      start_period: 90s
      timeout: 10s
      interval: 5s
      retries: 3
All the following variables live in a .env file:
  • PORT_APP_DAEMON → default: 5050
  • TZ → example: Europe/Berlin
  • HA_IP → IP address to your Home Assistant instance
  • PORT_HA → default: 8123
  • HA_APPDAEMON_KEY → generate a Long Lived Access Token in Home Assistant
And then, you need to edit (as mentioned by @DobriyS) the /opt/homeassistant/config/appdaemon/appdaemon.yaml file to make sure the Long Lived Access Token is added there too as well as the Home Assistant IP address:
# appdaemon.yaml
appdaemon:
  time_zone: CET
  latitude: 51.725
  longitude: 14.3434
  elevation: 0
  time_zone: Europe/Berlin
  plugins:
    HASS:
      type: hass
      ha_url: <HA_IP>:<PORT_HA>
      token: <HA_APPDAEMON_KEY>
      cert_verify: True
http:
  url: <HOST_IP>:<PORT_APP_DAEMON>
admin:
api:
hadashboard:
Neither do I, and it has started for me as well. I am on 2023.7.3, but it references 2023.4…
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/http.py:51
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 3 August 2023 at 20:47:29 (3 occurrences)
Last logged: 3 August 2023 at 22:58:50
[547300399440] from 127.0.0.1 (Home Assistant/2023.4 (io.robbie.HomeAssistant; build:2023.460; iOS 16.6.0)): Disconnected: Did not receive auth message within 10 seconds
[547270845264] from 127.0.0.1 (Home Assistant/2023.4 (io.robbie.HomeAssistant; build:2023.460; iOS 16.6.0)): Disconnected: Did not receive auth message within 10 seconds
[547138817424] from 127.0.0.1 (Home Assistant/2023.4 (io.robbie.HomeAssistant; build:2023.460; iOS 16.6.0)): Disconnected: Did not receive auth message within 10 seconds
Same here…
No clue as to why or where this comes from…
Source: components/websocket_api/http.py:50
First occurred: 09:42:37 (1 occurrences)
Last logged: 09:42:37
[140386469862208] from 192.168.50.151 (Home Assistant/2023.4 (io.robbie.HomeAssistant; build:2023.460; iOS 15.6.0)):
Same, not sure if this is caused by upgrading my docker or pfsense haproxy package. But before both, I had zero issues accessing it remotely or via dns. I can still access it via ip:port.
Same Problems. Recently updated to RPI Docker Version 2023.9.3 for home assistant/home-assistant.
SOLVED for my situation. HA was running but not frontend was loading. From the iPad and iPhone, I was only seeing a blank screen with a Gear for the (ā€œSettingsā€) ā€œCompanion Appā€ Settings. Go to ā€œDebuggingā€ and ā€œRESET FRONTEND CACHEā€. Close and restart the HA app and it works!
My android companion app would not load and finally show 3 options on-screen including ā€˜wait’. Diving into the HAOS LogViewer, I found this
Anyways, the issue was I had two wifi SSIDs (same network) at home, and in the companion app, I had added just one ā€˜known’ wifi SSID. My issue happens when I’m connected to the 2nd wifi SSID.
The solution for me was to add the second home SSID to the known network inside the companion app settings in the app.
how did you add another wifi ssid in the companion app? thanks
