Displaying a state of a switch on oled display
Hi there I have a issue with compiling esphome yaml file
this is my current setup below there error. when I compile I get the error. I want to show pool pump and light is on or off.
thank you kindly guys.
Error.
/config/esphome/pool_controller.yaml: In lambda function:
/config/esphome/pool_controller.yaml:234:23: error: ‘class esphome::gpio::GPIOSwitch’ has no member named ‘has_state’
  •       if (id(pool_light).has_state()) {*
/config/esphome/pool_controller.yaml:235:85: warning: format ‘%f’ expects argument of type ‘double’, but argument 7 has type ‘int’ [-Wformat=]
  •       it.printf(0, 60, id(font3), TextAlign::BASELINE_LEFT , "%.1f°", id(pool_light).state);*
/config/esphome/pool_controller.yaml:245:22: error: ‘class esphome::gpio::GPIOSwitch’ has no member named ‘has_state’
  •       if (id(pool_pump).has_state()) {*
/config/esphome/pool_controller.yaml:246:84: warning: format ‘%f’ expects argument of type ‘double’, but argument 7 has type ‘int’ [-Wformat=]
  •       it.printf(0, 60, id(font3), TextAlign::BASELINE_LEFT , "%.1f°", id(pool_pump).state);*
My Config
esphome:
esp32:
board: esp32dev
framework:
type: arduino
wifi:
ssid: “”
password: “”
manual_ip:
static_ip: 192.168.0.76
gateway: 192.168.0.1
subnet: 255.255.255.0
dns1: 8.8.8.8
dns2: 1.1.1.1
mqtt:
broker: 192.168.0.160
username: Mark
password:
ota:
safe_mode: True
password:
Enable logging
logger:
Enable Home Assistant API
api:
password: ‘mkg661204’
web_server:
port: 80
text_sensor:
  • platform: version
    name: “ESPHome Version Pool Controller”
dallas:
  • pin: GPIO13
    update_interval: 10s
binary_sensor:
  • platform: gpio
    pin:
    number: GPIO26
    mode: INPUT_PULLUP
    inverted: True
    on_press:
    • switch.toggle: pool_pump
  • platform: gpio
    pin:
    number: GPIO25
    mode: INPUT_PULLUP
    inverted: True
    on_press:
    • switch.toggle: pool_light
switch:
  • platform: gpio
    pin: GPIO32
  • platform: gpio
    pin: GPIO33
time:
  • platform: sntp
    servers: 192.168.0.252
    on_time:
    Every morning on weekdays in summertime
    • seconds: 0
      minutes: 00
      hours: 09
      days_of_week: 1,2,3,4,5,6,7
      months: 1,2,3,4,10,11,12
      then:
      • switch.turn_on: pool_pump
      • delay: 6 hours
      • switch.turn_off: pool_pump
    Every morning on weekdays in wintertime
    • seconds: 0
      minutes: 00
      hours: 12
      months: 5,6,7,8,9
      then:
      • delay: 60 minutes
  • platform: wifi_signal
    name: “WiFi Signal Pool Pump”
    update_interval: 60s
  • platform: uptime
    name: Uptime Sensor Pool Pump
  • platform: homeassistant
    entity_id: sensor.poolsense_temperature
    internal: true
  • platform: dallas
    address: 0xe63c67f6497c0628
    name: “Pool Inlet Temperature”
  • platform: dallas
    address: 0x233cc1e38167d828
    name: “Pool Return Temperature”
  • platform: adc
    name: “Pool Filter Pressure”
    pin: GPIO33
    unit_of_measurement: “PSI”
    accuracy_decimals: 2
    attenuation: 11db
    filters:
    • calibrate_linear:
      • 0.5 → 0.0
      • 2.5 → 30.0
font:
  • file: ‘arial.ttf’
  • file: ‘arial.ttf’
  • file: ‘arial.ttf’
  • file: ‘arial.ttf’
  • file: ‘arial.ttf’
  • file: ‘arial.ttf’
i2c:
sda: GPIO21
scl: GPIO22
display:
  • platform: ssd1306_i2c
    model: “SSD1306 128x64”
    address: 0x3C
    pages:
    • id: page1
      lambda: |-
      // Print “Pool Information” in top center.
      it.printf(64, 0, id(font3), TextAlign::TOP_CENTER, “Pool Information”);
      // Print time in HH:MM:SS format
      it.strftime(0, 60, id(font3), TextAlign::BASELINE_LEFT, “%Y-%m-%d %H:%M”, id(sntp_time).now());
    • id: page2
      lambda: |-
      // Print “Pool Temperature” in top center.
      it.printf(64, 0, id(font2), TextAlign::TOP_CENTER, “Pool Temperature”);
      // Print Pool Temperature (from homeassistant sensor)
      if (id(pool_temperature).has_state()) {
      it.printf(40, 60, id(font6), TextAlign::BASELINE_LEFT, “%.1f°”, id(pool_temperature).state);
    • id: page3
      lambda: |-
      // Print “Inlet Temperature” in top center.
      it.printf(64, 0, id(font3), TextAlign::TOP_CENTER, “Inlet Temperature”);
      // Print Pool Inlet Temperature
      if (id(pool_inlet_temperature).has_state()) {
      it.printf(40, 60, id(font6), TextAlign::BASELINE_LEFT , “%.1f°”, id(pool_inlet_temperature).state);
    • id: page4
      lambda: |-
      // Print “Return Temperature” in top center.
      it.printf(64, 0, id(font2), TextAlign::TOP_CENTER, “Return Temperature”);
      // Print Pool Return Temperature
      if (id(pool_return_temperature).has_state()) {
      it.printf(40, 60, id(font6), TextAlign::BASELINE_LEFT , “%.1f°”, id(pool_return_temperature).state);
    • id: page5
      lambda: |-
      // Print “Filter Pressure” in top center.
      it.printf(64, 0, id(font3), TextAlign::TOP_CENTER, “Filter Pressure”);
      // Print Pool Pump Pressure
      if (id(pool_filter_pressure).has_state()) {
      it.printf(40, 60, id(font6), TextAlign::BASELINE_LEFT , “%.1f°”, id(pool_filter_pressure).state);
    • id: page6
      lambda: |-
      // Print “Pool Light” in top center.
      it.printf(64, 0, id(font3), TextAlign::TOP_CENTER, “Pool Light”);
      // Print Pool Light
      it.printf(0, 60, id(font3), TextAlign::BASELINE_LEFT , “%.1f°”, id(pool_light).state);
    • id: page7
      lambda: |-
      // Print “Pool Pump” in top center.
      it.printf(64, 0, id(font3), TextAlign::TOP_CENTER, “Pool Pump”);
      // Print Pool Pump
      it.printf(0, 60, id(font3), TextAlign::BASELINE_LEFT , “%.1f°”, id(pool_pump).state);
interval:
  • interval: 10s
    then:
    • display.page.show_next: oled1
    • component.update: oled1
deep_sleep:
run_duration: 120s
sleep_duration: 60min
Please, please, post your code & logs properly. How to help us help you - or How to ask a good question
Hi Nickrout thank you kindly. I struggled but got it sorted. I will go read how to ask a good question. Sorry about that. thank you once again
Point 11 (or it may be 12) in that post tells you how to format code :slight_smile:
