You’re welcome. I recall the discussion but I’m surprised that you chose to create Template Sensors that use a long-winded if-else structure. In the original discussion, the suggestion was to use a list (to store the times and values) thereby making the template more compact. For example, here are the Circadian Brightness and Color Temperature sensors:
cl_brightness:
friendly_name: 'Circadian Brightness'
value_template: >
{% set hours = [[0,1],[500,25],[600,85],[630,105],[700,125],[730,190],
[800,210],[900,255],[1630,255],[1700,240],[1730,235],
[1800,225],[1830,200],[1900,175],[1930,125],[2000,115],
[2030,110],[2100,100],[2200,85],[2230,25],[2300,1]] %}
{% set t = states('sensor.time').replace(':','')|int %}
{% set ns = namespace(level = 0) %}
{% for h in hours if t >= h[0] %}
{% set ns.level = h[1] %}
{% endfor %}
{{ ns.level }}
cl_color_temp:
friendly_name: 'Circadian Color Temperature'
value_template: >
{% set hours = [[0,1],[500,500],[600,450],[630,400],[700,350],[730,350],
[800,325],[900,300],[1630,350],[1700,360],[1730,370],
[1800,375],[1830,400],[1900,425],[1930,450],[2000,465],
[2030,475],[2100,500],[2200,500],[2230,500],[2300,500]] %}
{% endfor %}
{{ ns.level }}
Anyway, it’s your choice.
BTW, in your Circadian Color Temperature sensor, the final else
provides this [255, 125, 0]
for color_temp
instead of an integer value.
Service data attribute | Optional | Description |
color_temp | yes | An integer in mireds representing the color temperature you want the light to be. |
