After an unscheduled reboot and restart of Hassio in the evening I discovered that the status of the blinds was incorrectly set to open. After reading this forum and the help from @ Schneider Cover template last state after reboot I found the solution:
1. Create boolean:
input_boolean.yaml
lux_west_left:
name: "Status lux west left"
icon: mdi:glassdoor
lux_west_right:
name: "Status lux west right"
icon: mdi:glassdoor
2. Modify the covers
# ZIGBEE LUXAFLEX WEST #
covers:
lux_west_left:
value_template: "{{ is_state('input_boolean.lux_west_left', 'on') }}"
entity_id: input_boolean.lux_west_left
friendly_name: "Lux west left"
open_cover:
service: script.open_west_left
close_cover:
service: script.close_west_left
stop_cover:
service: switch.turn_off
entity_id:
- switch.0x00124b001d863d78_switch_bottom_right
- switch.0x00124b001d863d78_switch_bottom_left
covers:
lux_west_right:
value_template: "{{ is_state('input_boolean.lux_west_right', 'on') }}"
entity_id: input_boolean.lux_west_right
friendly_name: "Lux west right"
open_cover:
service: script.open_west_right
close_cover:
service: script.close_west_right
stop_cover:
entity_id:
- switch.0x00124b001d863d78_switch_top_right
- switch.0x00124b001d863d78_switch_top_left
# END OF CONFIGURATION FILE #
Now you need to test your system by a restart/reboot and check if the boolean has the correct value.
I have added the booleans input_boolean.lux_west_left and input_boolean.lux_west_left to Lovelace:
This way it is very easy to correct the status of the boolean. If the ‘boolean-switch’ in Lovelace is on, than the blinds are open. So make sure the status of the boolean mirrors the actual status of the blinds.
