For a rookie a DIY startup tutorial would be great… but google doesn’t have it yet.
Still fighting to connect via ethernet…
Please post your code properly.
‘Does not work’ is unhelpful.
Solved the ethernet, connenction and receive data from sensor looking at ESP log.
In HA lovelace tells that the 3 sensors are unknown or unavailable…
Current code:
esphome:
platform: ESP32
board: esp32-evb
ethernet:
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO0_IN
phy_addr: 0
manual_ip:
static_ip: 192.168.1.110
gateway: 192.168.1.1
subnet: 255.255.255.0
#wifi:
# ssid: "gaac"
# password: "xxxxxxxxxxxx"
# ap:
# ssid: "Evb001 Fallback Hotspot"
# password: "xxxxxxxxxxxxxx"
#captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
web_server:
port: 80
i2c:
sda: 13
scl: 16
scan: True
- platform: bme280
temperature:
oversampling: 16x
pressure:
humidity:
address: 0x77
update_interval: 10s
Some logs might help.
