With the new updates I am seeing with HA and the powerful automation tools I am moving back from node red to HA. I just wanted to check my logic on this automation is correct. I want to unlock the front door when I return from my walk. Using camera person occupancy as the wait to actually trigger. Seeing if what I made look ok?
alias: unlock door when i walk home
description: ""
- platform: zone
entity_id: person.hans_van_der_drift
zone: zone.home
event: enter
- condition: state
entity_id: sensor.iphone_mini_13_activity
attribute: Types
state: Walking
for:
hours: 0
minutes: 0
seconds: 0
- condition: state
entity_id: binary_sensor.konnected_7e1888_zone_10
state: "off"
- parallel:
- wait_for_trigger:
- type: occupied
platform: device
device_id: ffa636b1fa9b8d5e98dd0aa1662b1e7e
entity_id: binary_sensor.garage_frigate_person_occupancy
domain: binary_sensor
continue_on_timeout: false
timeout:
hours: 0
minutes: 2
seconds: 0
milliseconds: 0
- wait_for_trigger: []
timeout:
hours: 0
minutes: 2
seconds: 0
milliseconds: 0
- service: lock.unlock
data: {}
entity_id: lock.front_door_lock
type or paste code here
The iPhone activity sensor gives a list. Normally this list contains one item, but keep in mind there can be multiple ones (probably when the certainty isn’t that high). There is a confidence attribute you can check too. Regardless, I think, change that to a template condition and take the first element. I’ve not been able to confirm this, but it seems the first element will always be the best guess.
What is the purpose of the 2nd wait for trigger?
This is perhaps a matter of taste, but I’d use a state trigger for the zone: Just trigger on the state with a to.
For the first wait for trigger (and in general) refrain from using device triggers. A state trigger will be much simpler and more maintainable. There are some posts on the forum explaining this in detail.
I posted the incorrect code. It should have been a second camera in case I come in from another direction.
I have changed it to a “State Trigger”
I did some reading and changed the code to state triggers also.
This is the only part I am yet to work out. If you have an example, I would appreciate it. I need to harness the power of templating.
Thanks again.
description: ""
- platform: state
entity_id:
- person.hans_van_der_drift
to: home
- condition: state
attribute: Types
state: Walking
for:
hours: 0
minutes: 0
seconds: 0
- condition: state
state: "off"
- parallel:
- wait_for_trigger:
- platform: state
entity_id:
- binary_sensor.front_door_frigate_person_occupancy
to: "on"
timeout:
hours: 0
minutes: 2
seconds: 0
milliseconds: 0
- wait_for_trigger:
- platform: state
entity_id:
- binary_sensor.garage_frigate_person_occupancy
to: "on"
timeout:
hours: 0
minutes: 2
seconds: 0
milliseconds: 0
data: {}
Pieter, I think I have it all working now. Will test in the real world tomorrow. Looking at your below code, how would you handle you and a passenger (in my case my wife) with the same automation to open the garage door? In my case the door would close again.
- alias: "Open Garage Door When Arriving By Car"
initial_state: true
- platform: state
entity_id: binary_sensor.pieter_present
to: "on"
- condition: and
conditions:
# prevent a glitch in case the cover was recently closed
- condition: state
entity_id: cover.rhs_garage_door
state: "closed"
for:
minutes: 5
- condition: time
after: "07:00:00"
before: "23:00:00"
# i must be arriving by car
- condition: state
entity_id: binary_sensor.pieter_driving
state: "on"
# my cover for my car
- condition: state
entity_id: binary_sensor.rhs_garage_occupied
state: "off"
# proxy for the alarm being off
- condition: state
entity_id: binary_sensor.rouve_present
state: "on"
for:
minutes: 5
- service: cover.open_cover
I’m assuming your door/cover doesn’t have state (i.e. you don’t know whether it’s open or not). Is my understanding right? If that’s the case, I think it would really help to add a door sensor. When you have that, you can add mode: single to your automation and also a condition to check whether the door (cover) is already open. There’s very little cost to triggering an automation that’s then aborted due to a condition.
If you don’t have state, then I’d still add mode: single, but it will only cover you if both devices changes (update) their location very close apart. I think the optimistic mode of a template cover might help you. Otherwise, you could create your own helper (like an input boolean) to try and maintain a synced state. These things just tend to get out of sync… The optimistic mode probably has the same challenge.
Perhaps the most robust option for this scenario (where you don’t know the cover’s state), is to simply check when last the lock’s status was triggered. Putting this in a condition under your actions will say: Only if the lock’s status has changed more than a minute ago, I will attempt to unlock it. If you then trigger the automation on both people, they will race towards the unlock call, but once one is past this point, the other will fail (given internal states have updated quickly enough).
Regarding my code, we have split garage doors (two singles) and my wife doesn’t like the automatic opening. Since I haven’t yet automated my alarm or connected it to HA, I’m using her being home as a proxy for the alarm being off.
The last_changed “attribute” isn’t accessible via the state_attr function (but you’re entirely right to have tried this, because intuitively it makes sense). It’s actually a property of the state object(s). You’ll see e.g. the attributes is then a property that contains all the attributes.
My automation. (I have made two, one for garage opening, one for door unlocking) have yet to work as intended in real life testing… Ill post both after I get it to work.
Sorry for all the questions, your answers make me ponder and sometimes the logic baffles me.
- alias: "Set Pieter's Driving State"
initial_state: true
- platform: state
entity_id: sensor.pieter_activity_type
to: "Automotive" # from anything else
- platform: state
- service: "input_boolean.turn_{{ 'on' if is_state('sensor.pieter_activity_type', 'Automotive') else 'off' }}"
entity_id: input_boolean.pieter_driving
I have emulated your code and it works great, in a bi-directional mode. So, if I drive, the input will toggle, or if I toggle, the boolean will toggle.
But this code for Hans Presence works only one way. Meaning the Boolean will toggle the input, but when I leave the zone the input boolean remains ON.
Here is my code:
alias: Toggle Input B of Hans present or away
description: ""
- platform: state
entity_id:
- binary_sensor.hans_present
to: "on"
- platform: state
entity_id:
condition: []
- service: >-
input_boolean.turn_{{ 'on' if is_state('binary_sensor.hans_present', 'on')
else 'off' }}
entity_id: input_boolean.hans_present
enabled: true
What is the definition of binary_sensor.hans_present?
Were there perhaps any errors in your log?
This version is a bit more compact and pretty much does the same thing. I can’t see anything wrong immediately, unless there’s a circular reference where the binary sensor uses the input boolean, which triggers the automation, etc.
- platform: state
entity_id:
- service: >-
input_boolean.turn_{{ 'on' if is_state('binary_sensor.hans_present', 'on') else 'off' }}
There was also a enabled: true that I removed that looks unfamiliar to me. Was that perhaps added by mistake?
So, it seems when the automation turns the input booean on it stays on, as there are two states that triger the state.
Which leads me to another question, why do you have Input Booleans and a Bianry sensor? I can see the input it useful for testing but what other cased would you use one over the other?
The binary sensor uses the combination of the input boolean and the person state (if either is home/on, the person is definitely home).
The person entity is linked to the companion app (and hence uses GPS location). The input boolean is set by a home automation (iOS shortcuts app with my Apple TV being a home hub), since the home hubs can check presence too.
Lots of people uses multiple inputs for faster and more certain updates, typically using a Bayesian sensor, but I’ve found this simplified version to work well for me. It’s from a time when the companion app updates weren’t that reliable (a few years ago). Not it’s just a backup.
So, in short, I only ever use the binary sensor. The input boolean is only references by the sensor and set externally.
