This is one and only hardware which I am not able to integrate ā¦
I donāt have any coding knowledge so just copy and paste from a working integration
can someone help me? i followed the instruction in here dohome HA git
after i copy all file to custom_components folder and add dohome: in config, when i check config, it shows " Component error: dohome - Integration ādohomeā not found."
Has anyone got the DoHome integration working with the latest HA? I find I add the custom component and see in the log that the component is found and it found my light. I even see in the log that the light has been added to HA, however the entities are not available.
Gary
Hi, noticed my local shop is selling a bunch of dohome homekit devices.
Just wondering if their homekit firmware are only using ESP chipset?
Iām considering buying some of their homekit led bulbs and flashing tasmota or esphome.
QUICK UPDATE:
I tested my DoHome homekit sensor and added it using homekit (step 1 is to connect to the wifi which starts with homekit) using the homekit integration (it auto discovered after network join) then i just entered the pairing code 123-45-678 and when it asked me, i clicked on use unsafe thingy or whatever and then I reentered the pin. Thats all. It was a bit weird as an example messure rate of the sensor (for both temperature and humidity) was very āexcactā (this was the āmessureā 21,6999893188477 Ā°C) yeah thats it byeeee
