Hi, I’m starting to understand the logic of esphome code and I realize now that my previous post had some silly questions. Please disregard them.
I got it all working with the following code:
esphome:
on_boot:
priority: 600
then:
- binary_sensor.template.publish:
state: ON
state: OFF
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "####################################"
ota:
password: "###############################"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "I3-Kitchen Fallback Hotspot"
password: "##############"
captive_portal:
# Physical wall switch sensor automation
binary_sensor:
- platform: gpio
pin:
number: GPIO12
mode: INPUT
name: i3-kitchen Input 1
internal: true
filters:
- delayed_on_off: 50ms
on_state:
then:
- if:
lambda: 'return id(template_sw1).state;'
then:
state: OFF
else:
state: ON
on_multi_click:
- timing:
- ON for at most 500ms
then:
- if:
lambda: 'return id(template_sw2).state;'
then:
state: OFF
else:
state: ON
- timing:
- OFF for at most 500ms
then:
- if:
then:
state: OFF
else:
state: ON
# Virtual switches
name: "Kitchen counter LED switch"
name: "Kitchen cabinets LED switch"
There is just one small issue with the above code. When I quickly flip the wall switch ON->OFF->ON or OFF->ON->OFF, the on_multi_click automation works and it toggles the value of the template_sw2 but it also momentarily changes the value of the template_sw1 which is undesirable behaviour.
Would you have any idea how to fix it?
