DS-KD8003 - DS-KV8113 - DS-KV8213 - DS-KV6113 - DS-KV8413 and .... integration Hikvision HikConnect Video intercom doorbell
No, in ivms you have devices right? Just remove it from there… It maybe pickups the signal from there
But yesterday when i test i has closed IVMS-4200. No open. But i know that when i have open IVMS-4200 it suppoort info about callstatus and also i can talk by IVMS-4200 and open door.
Only has open HA…
Today logs, first open door 1
Trying to unlock door 1... Stdin message: unlock1
Door: 1 unlocked by SDK!
Door unlocked, trying to update: sensor.hikvision_door
Unlocked door ID : 9731
Unlocked by: [97, 98, 99, 100, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
Door 2
Trying to unlock door 2... Stdin message: unlock2
Door: 2 unlocked by SDK!
Unlocked door ID : 9987
Again door 2
Unlocked door ID : 10243
Yeah, I have another idea, seems I can also capture the lock name instead of id, will try that later, maybe it’s the same
ok
But how use still image ? If you add to you addon ?
And did you have any solution idea how catch callstatus as IVMS-4200 get it ?
still image is not going to work, you need the motioneye addon, or use the ffmpeg script to create an snapshot
example:
@grimpy is going to check if he have callstatus on his device, he has the same model
@pepeEL , try upgrading to 2.9.1
it should now display a lockname also , do you see something there?
But still image you write that probably you can add also…
But in addon see that add stream from camera… how we can use it ?
Also please add changelog to addon to we can see what is new in new version.
no, i cant write still image in the SDK, the script doesnt work for intercoms, only cameras
so you need to grab a still image from the rtsp stream using ffmpeg, cant do that in addon
Logs for Door 1 with error
Unlocked door ID : 10499
sh: 1: Syntax error: end of file unexpected
crap, too bad :frowning:
gonna revert it
@pepeEL , do you have defined a lockname in your ivms ? or is it empty?
No i dont have any confuguration in IVMS. I have only add VideoIntercom and my NVR with Cameras. Nothing more.
Yeah, but for my intercom, I can give the lock names, maybe it’s because of an empty name…
I can not problably or i dont know how.
You don’t have the admin password?
Should be easy, just configure the outdoorw there is a tab somewhere to configure the locks, like names and seconds
i have admin password but on my intercom on configuration lock i have only to set time for first and second lock. The same time. Can not set name and other time to first and other time to second lock.
Ah ok, maybe indeed not supported on yours’… Maybe time to invest in new doorbell :slight_smile:
It is my view… sorry polish lang
