I have the KV-6113 running through scrypted + the motion detected alerts sent over via an HACS integration called Send Webhooks.
Scrypted is very alpha right now and I am patiently waiting for homebridge to integrate HKSV, which should happen any week now. I have noticed that the lag time to open a stream in Scrypted is near zero (due to the pre buffer HKSV requires)
On this model isapi is no available. I also has KV8102 and now i use integration and he only share script to open door.
I still waiting to will be available press ring status to HA
Well yes I want to replace only because of doorpress events actually (and also because I can use RTSP only from 1-2 sources then crashes, while other hikvision camera I can connect 3-4-5 viewers without problems
For the ARM SDK, donāt expect it soon, seems hikvision doesnāt have a developer in houseā¦ They are hiring people at this momentā¦ They are looking for a freelancee with experience on arm processor
