ESP is an official integration for HA
there are verry cheap and small boards, that have wifi chips , you can maybe even place it behind the a panel and power it, or place it where you want
then hook up 2 cables from the relay, that you configure as calling linkage, and hook them up to the board on any random input connector, that input connector you can read with HA, its a binary sensor
I have indoor station power by POE from HikVision switch. How i can power this ESP32 from indoor station ?
Or if i use POE by RJ45 maybe i can use 2 wire for this relay ? And ESP maybe i can connect near switch POE ? But i dont know that i can use 2 wire from RJ45ā¦?
Yes, i placed the board, next to my switch, so NOT on the side of the indoor panel
UTP is 4 pairs, 8 cables, but the hikvision are 802.3af compatible, so that means you can use 2 pairs for POE power and data, so you have 2 pairs left on your UTP cable, so one pair can be used for your boardā¦ , when using only 2 pairs for POE and DATA, the monitor is on max 100 Mbit instead of 1 GBit, but more then enough!!
great idea. Anyone did this, it is cconfirmed it works?
EDIT, mine has ISAPI so no need for this. I will just use this below that should be enough? I tried the CURL command and response is that sensor is in IDLE.
I tried to RING the doorbell, and the STATUS of the sensor in Home assistant does not change (I could not check the CURL command while ringing because intercom is on streest so not sure if CURL command changed status)
Hi Guys.
I will go with the relay from the DS-KH8350-TE1.
Can anybody tell me, why i measure 5v on the Relay contact?
On the manual there itās not clear, which Common corresponds to AO1 and AO2.
If i ring, the Voltage drops to zero, so iām sure it works.
As i understand relays, it should be a potentialfree contact, which i can use to close input to ground of my Raspberry py.
Since Raspberrys only allow 3.3V iām a little slow an hanging up 5V.
Thanks in advance.
I installed custom firmware (v2.2.45 build 210721) on my KD8003, and did a factory reset (both through iVMS and ISAPI), but Iām still not seeing the CallStatus change from āidleā.
hmm, if receiving the heartbeat, something went wrong i think
i had it also first time, no events in the streamā¦ try resetting again? i did a hard reset afterwards
Hi, I have 2 DS-KD8003-IME1, the first has firmware 2.0.8build210426 and works fine SIP but I donāt have ISAPI and ONVIF, the second has firmware 2.2.50build210728 and ISAPI and ONVIF work fine but not SIP, it does not perform the call, there is no card where to enter the number called.
Do you have a firmware with working SIP and ISAPI?
I have the custom, 2.2.47 ā¦ Isapi and sip work, I use rtsp instead of onvifā¦ What doesnāt work with Sip?? Menu missing? What PBX do u use? Can you register?
