DS-KD8003 - DS-KV8113 - DS-KV8213 - DS-KV6113 - DS-KV8413 and .... integration Hikvision HikConnect Video intercom doorbell
Where i can find this:
"bearer" : "YOURLONGBEARERTOKEN",
in HA, go to your user profile, scroll down to the bottom, there you can create a long live token
I try test it with Hikvision 1 generation VideoIntercom.
Motion detection in my model i know that is unavailable.
Only can test callstatus and unlock 1 and unlock2(gateway)
perfect
is port 80 also closed for you? Were you able to send isapi? for open door?
Yes port 80 is closed in 1 generation…No i can not send ISAPI…
ok, should work now, that was the reason why u used hikconnect cloud?
and what about rtsp stream? port 554 , does that work for you +?
Yes rtsp works on port 554 but only stream. No image for this camera.
Yes now i use hik cloud because ISAPI now working…
But tell me i have Door 1 and door 2. Door 2 is my gateway…
Is any chance to also it will be support ? Because sensor door is only one in template…
And if i dont have motion detection i must create sensor in template for it and configure it in addon ?
yeah, i think i can add that a seperate template sensors
or maybe as attribute
provide me later the add-on log, when you open door 1 or door 2 , should be outputted in the log, i want to see the difference… i cant test, only have 1 door :slight_smile:
You thin in logs on addon ?
next step is to provide indeed a still image, will be the next improvemt (if possible in sdk)
very very good
Now after install addon i have in LOGS only:
Hikvision SDK Add-on started! Listening for events…
loop[2] find 8 mac and 16 ip
To provide you logs i must open doo1 and then open door 2 from my LCD VideoIntercom , and then send you logs ?
yes, if a door opens, you see some event state indeed
you can now also a door using an HA service, you dont need todo it from an indoor station, use below service
service: hassio.addon_stdin
  addon: a53439b8_hikvision_sdk
  input: unlock1
ok when come back to home from work i test it and send you today evening…
ok… But tell me for what is a sensor template for door ? What it show ? When some door 1 or door 2 was open ?
is the addon name also for you : a53439b8_hikvision_sdk ?
yes i have the same name.
yes, when a door open, the sensors goes to ON for 2 seconds , the back to OFF state
i will add the door1 or door2 as an attribute of that sensor
good…
And also wait for still image for camera… thios also will be good.
yeah, it will take time :slight_smile:
you can also use the MotionEYE addon, it will provide you a camera entity
