I write to hikvision qestion but no aswear… I give you an infor when i recived it.
hi, the addon runs in another container, you dont see it
you can acces it with a command like:
docker exec -it NAMECONTAINER /bin/bash
not sure if the appertment number is avaible
if you want to test the script just local, use this version, easier to test
if you can find the numbers, i’ll add it to addon too
Yes 1.5.1. I’m started to suspect the power supply of the outdoor unit to be unstable.
For our model only works door unlock by SDK.
Call status no working…
I write to support with ask how he resolved it that call status is showing in IVMS-4200 but no reply…
Maybe other user also can write to support to ask about it… Maybe other support no Polish reply on this question.
i think he knows, @grimpy modified the code also to make open door happen with sdk
but stay tuned @pepeEL , he as a working solution for you
he is busy on verry nice project
stat tuned, details will follow over next weeks, when we know whats possible
but what will be possible, is that you can have a call event with your system
Good Job very very thanks
If you need tester i am ready.
no need for testers
no good why
there is nothing to test yet, it already works
Hi, in the HikConnect addon I get
NET_DVR_Login_V30 failed, error code = 7
That means an network error? Is the IP of HA on same subnet as doorbell? You are connectinfg to outdoor right? What device do you have?
yes it was working before, I think. KV8213
192.168.1.12 HASS
192.168.1.74 KV8213
try an uninstall reinstall, sometimes its needed when updating addons
nope same
Sorry now I am lost whats the differenxe between hiconnect and hikvision-sdk.
I just need to open my door from home assistant, it was working untl yesterday, now not
Do you open the door with the new addon service? Because that open door feature is only present since a week…he new feature since last week? Or with ISAPi command? Try rebooting the outdoor
Hikvision-sdk is the addon, how did you open door? With what Service?
Sorry I have lots of work, so few time to fix my home assistant, but is used by the whole family so when something is broken is a problem for me
the entity is
lock.main_door_station_lock
Is hik-connect entity so is it hikconnect or hikvision-sdk?
Hikconnect gets the error then it crashes after some minutes
p.s. hikconnect is different from hik-connect, yes?
probably not, which is this new service?
anyway it crashes
2-03-16 09:13:44 INFO (SyncWorker_1) [supervisor.docker.addon] Starting Docker add-on local/amd64-addon-hikconnect with version 1
22-03-16 09:13:53 ERROR (SyncWorker_1) [supervisor.docker.interface] Container addon_local_hikconnect is not running
