Yes, thats what I said on my first reply, you need digest :+)
Hiā¦ Any info when it will be available ?
no, not yet, still testing
Today i get update to version 2.9.7
What is new in this version Addon SDK ?
nothing, was jus trying to output more debug data, but failed
gonna leave it like it is
And get next update version 3.0.0.
Nothing changed. , Just ignore
In that addon, there is nothing to add anymore :+)
I will release a new addon, with a preconfigured proxy, so you can make use of asterisk and the sip cardā¦ So you can actually receive calls and pick up with HA (Lovelace sip card)
Then you will also have your call sensor :+)
The 2 add-ons are completely seperate
The SDK addon is just for events and open doorā¦ While the new addon is a PBX integration, that connects to the indoor station
Hi
Today i recived info from support that on 1 generation video interco ring to IVMS-4200 when we setup in intecom to call to centre. Not call to indoor panel.
Very very very good news! Well done!
One question. Is this going to work with raspberry installations of HA?
Yes, should, I donāt use any SDK for it
Today i get this reply from support:
In the case of firmware v.1.5.1, the KV8102 station can call only to the monitor or only to iVMS (depending on the configuration). In older firmware versions, it was possible to configure a short and long press of the call button - one for iVMS, the other for the monitor.
Can anyone confirm this firmware works with: DS-KV8103-IME2 ? Thanks!
What firmware?
Guys, anyone in here with 2 indoor panels? who can make me a trace?
GUYS , i have some VERY good NEWS to tell you!!! A nice project is comingā¦
EDIT: first version released!!!
Readme here
Be aware, its first version, maybe i need to update fix some settings somewhere
test and keep me updated!
and first question
I already have MariaDb installed with the below configuration. Can I put 2 databases, in MaraDb its written is possibleā¦
But how to put two separate logins?
databases:
- homeassistant
logins:
- password: xxxx
username: homeassistant
rights:
- database: homeassistant
like this:
databases:
- homeassistant
- opensips
logins:
- password: homeassistant
- password: opensipsrw
username: opensips
rights:
- database: opensips
username: opensips
ok thanks,
I donāt have to put nowhere the outdoor station IP address?
nope , outdoor station IP is not needed, you dont need access to it, all is based on the indoor station
Ok, I changed my laptop, so I downloaded again IVMS on my windows laptop, and added the Outdoor station and the Indoor station (I have other 10 camera will not add it now)
Now what do I do, not sure understood this
"As I told before, this addon registers on the indoor station, you need to add it first manually with the IVMS software, make sure you input the correct data, sice its now hardcoded in this Add-on:
For serial use: Q12345678, for No: 5, enter āAdminā password, the the IP is your HA instanceā¦ I used 5, because maybe there al already users with 4 indoor stations, so this will be the 5th :-)"
