DSMR Reader Add-on for Home Assistant
With the latest releases of Home Assistant, I’m now seeing this error message in the logs:
Logger: homeassistant.components.sensor
Source: helpers/entity_platform.py:207
Integration: Sensor (documentation, issues)
First occurred: 07:54:02 (1 occurrences)
Last logged: 07:54:02
The dsmr platform for the sensor integration does not support platform setup. Please remove it from your config.
What do I need to do to resolve this issue? Thank you.
Home Assistant 2023.6.3
Supervisor 2023.06.4
Operating System 10.3
Frontend 20230608.0 - latest
my dsmr reader is’nt sending any mqtt messages
the outbox is 5000 message’s but cant delete it.
i have the broker settings right,
installed the dsmr reader addon again but also doesnt help
it looks like there is an bug in the mqtt section
@sanderdw:
Since i updated TimescaleDB to version 3.0.2 i do have the next error in the log off the addon:
" ERROR schedule execute_scheduled_processes 39 | (OSError) dsmr_backup.services.backup.run errored: b’pg_dump: error: server version: 15.3; pg_dump version: 14.5\npg_dump: error: aborting because of server version mismatch\n’ "
Also i do get in DSMR reader the warning:
" Backup creation failed, please check the dsmr_backend logfile ", and there is see in the “configpanel” , “planed process”, “create Daily backup” its trying to make a backup.
Did try to restart both addons and also did try in the “timescaleDB” addon to use the function “retry_ upgrade”. But that also not fixing the problem.
Edit 20-7: Vacuum DB and compleet restart HA system solved the warning “Backup creation failed” in the addon. But still got the other error in the log of the addon for version mismatch. And dont have any backup files from 14-7 from dsmr reader on the drive
Seeing the same behavior here.
HA supervised on Intel machine (No VM’s)
I don’t have any issue’s running DSMR Reader Add-on - Release: 1.10.1 with TimescaleDB Add-on - Release: 3.0.2 on a ARM platform (Raspberry PI 4)?
Still issue’s? Maybe check in the Timescale addon thread? Home Assistant Add-on: PostgreSQL + TimescaleDB - #181 by tldp
@sanderdw : Sorry for the late reaction. But holiday and busy. Problem is still there. But i did asked in the requested topic.
@sanderdw ,
Every week (since July this year) I get this notification in the DSMR Reader that the backup failed:
“Sept. 18, 2023: Backup creation failed, please check the dsmr_backend logfile.”
When I look in the “Logboek” page of the DSM Reader addon then I repeatively see the following messages:
2023-09-19 16:30:57,071 ERROR schedule execute_scheduled_processes 39 | (AttributeError) dsmr_backup.services.backup.run errored: ‘NoneType’ object has no attribute ‘read’
127.0.0.1 - - [19/Sep/2023:16:31:07 +0200] “GET /about HTTP/1.1” 200 15212 “-” “curl/7.83.1” “-”
127.0.0.1 - - [19/Sep/2023:16:31:22 +0200] “GET /about HTTP/1.1” 200 15212 “-” “curl/7.83.1” “-”
Do you have any clue what the error is about, and what I need to do to get the backup working again?
On the Internet I am reading that this pg_dump error occurs when there is a discrepancy between the pg_dump and server versions. The pg_dump backup tool is designed to work with specific server versions, and if the versions do not match, compatibility issues may occur.
However I have no idea how to solve this.
Thanks, Jeroen.
I think the problem is that the DSMR Reader Addon is using too old version of the “pg_dump” backup tool.
Yes could be the case indeed, i will check this later. Don’t have a lot of free time currently because of a newborn son :slight_smile: .
2023-09-25: DSMR Reader Add-on v 1.10.2, DSMR-reader v5.10.3
Changelog here
@jcjdammers hould be fixed with the new update (pg_dump updated).
@sanderdw , Many thanks, backup works again after the update. Congrats with your son!
Hoi, behoorlijk thuis inmiddels in Home Assistant en wil nu kijken naar dmsr reader. Ik heb de addon, de intergratie en de database geïnstalleerd.
Ik heb een homewizzard P1 wifi meter. Hoe krijg ik nu alles te zien in een leuk dashboard en kan ik het dashboard van Home Assistant met zonnepanelen ook nog gebruiken?
Edit: Ik heb het ip-adres van mijn Home Wizzard P1 ingevuld maar krijg geen data?
  File "/app/dsmr_backend/mixins.py", line 96, in run_once
    self.run(data=self.data, **options)
  File "/app/dsmr_datalogger/management/commands/dsmr_datalogger.py", line 29, in run
    telegram = next(self.telegram_generator)
  File "/app/dsmr_datalogger/scripts/dsmr_datalogger_api_client.py", line 43, in read_telegram
    raise RuntimeError("Failed to connect: {}", error) from error
RuntimeError: ('Failed to connect: {}', SerialException('Could not open port socket://localhost:23: [Errno 99] Address not available'))
Starting DSMR Reader - datalogger...
Current logging level set to "ERROR". More information can be found here: https://dsmr-reader.readthedocs.io/en/latest/how-to/troubleshooting/enabling-debug-logging.html
2023-10-03 17:27:19,123 ERROR    mixins       run_once                        107 | dsmr_datalogger.management.commands.dsmr_datalogger: [!] Exception raised. Traceback (most recent call last):
  File "/usr/local/lib/python3.11/site-packages/serial/urlhandler/protocol_socket.py", line 63, in open
    self._socket = socket.create_connection(self.from_url(self.portstr), timeout=POLL_TIMEOUT)
  File "/usr/local/lib/python3.11/socket.py", line 851, in create_connection
    raise exceptions[0]
  File "/usr/local/lib/python3.11/socket.py", line 836, in create_connection
    sock.connect(sa)
OSError: [Errno 99] Address not available
  File "/app/dsmr_datalogger/scripts/dsmr_datalogger_api_client.py", line 39, in read_telegram
    serial_handle = serial.serial_for_url(
  File "/usr/local/lib/python3.11/site-packages/serial/__init__.py", line 90, in serial_for_url
    instance.open()
  File "/usr/local/lib/python3.11/site-packages/serial/urlhandler/protocol_socket.py", line 66, in open
    raise SerialException("Could not open port {}: {}".format(self.portstr, msg))
serial.serialutil.SerialException: Could not open port socket://localhost:23: [Errno 99] Address not available
127.0.0.1 - - [03/Oct/2023:17:27:21 +0200] "GET /about HTTP/1.1" 200 16126 "-" "curl/8.0.1" "-"
Kan iemand me helpen met het koppelen van de Homewizard p1 aan dsmr reader?
Volgens HomeWizard P1 As Remote for DSRM-Reader · Issue #301 · xirixiz/dsmr-reader-docker · GitHub wordt het niet echt ondersteund en zou je iets met aparte scripts moeten gaan doen…
Optie 1 is zelf iets naar API — DSMR-reader v5 documentation sturen.
Optie 2 is iets met die plugin optie doen maar dat ondersteunt de huidige addon niet.
Ik heb besloten de seriele kabel weer te gaan gebruiken en krijg nu data binnen. De reden dat ik deze addon heb geïnstalleerd was omdat ik sinds ik een nieuw Ziggo modem heb mijn meterstand niet meer kon uploaden naar Mindergas.nl. Ik heb mijn token ingevuld in dsmr, maar ook nu wordt er niets geupload, so sadd :cry:
I would like to create a (restfull) sensor of the net returned energy for the current energy supplier. (The current year sensors are not suitable because my energy contract does not start at the first of January) In order to do that I need the API documentation. Problem is that when I go to “support” and click on “view API documentation” I get a 401 unauthorized message.
How can can I solve this? Or is there any website where I can find de API docs? Or even better; does anyone have an example for such a sensor?
Wie kan mij helpen?
Sinds een aantal maanden lopen de dagstatistieken achter. Ik zie geen foutmeldingen in de log?
Hij loopt als plugin op home assistent.
Bedankt!
[ INFO ] Enabling IFrame...
[ INFO ] Running post configuration...
Operations to perform:
  Apply all migrations: admin, auth, contenttypes, dsmr_api, dsmr_backend, dsmr_backup, dsmr_consumption, dsmr_datalogger, dsmr_dropbox, dsmr_frontend, dsmr_influxdb, dsmr_mindergas, dsmr_mqtt, dsmr_notification, dsmr_pvoutput, dsmr_stats, dsmr_weather, sessions
Running migrations:
  No migrations to apply.
559 static files copied to '/var/www/dsmrreader/static'.
Updating password of superuser "admin"
Deactivating any other existing superusers
[ INFO ] Checking for CLIENT CERTIFICATE AUTHENTICATION configuration...
[ INFO ] ENABLE_CLIENTCERT_AUTH is disabled, nothing to see here. Continuing...
[ INFO ] Checking for NGINX SSL configuration...
[ INFO ] ENABLE_NGINX_SSL is disabled, nothing to see here. Continuing...
[ INFO ] Checking for HTTP AUTHENTICATION configuration...
[ INFO ] ENABLE_HTTP_AUTH is disabled, nothing to see here. Continuing...
[ INFO ] Configuring DSMR Reader to run all processes in a single container with a serial or ipv4 datalogger...
[ INFO ] Using a serial connection for the DSMR Reader remote datalogger...
[ INFO ] Fixing /dev/ttyUSB1 security...
[ INFO ] Adding serial input method configuration settings...
[ INFO ] Adding DSMRREADER_REMOTE_DATALOGGER_SLEEP to the DSMR Reader remote datalogger configuration...
[ INFO ] Adding DSMRREADER_LOGLEVEL to the DSMR Reader configuration...
[cont-init.d] 20-set-app-defaults: exited 0.
[cont-init.d] done.
[services.d] starting services
Starting DSMR Reader - nginx...
Starting DSMR Reader - backend...
Starting DSMR Reader - webinterface...
[services.d] done.
[2023-10-21 15:07:39 +0200] [499] [INFO] Starting gunicorn 20.1.0
[2023-10-21 15:07:39 +0200] [499] [INFO] Listening at: unix:/tmp/gunicorn--dsmr_webinterface.socket (499)
[2023-10-21 15:07:39 +0200] [499] [INFO] Using worker: sync
[2023-10-21 15:07:39 +0200] [523] [INFO] Booting worker with pid: 523
127.0.0.1 - - [21/Oct/2023:15:07:44 +0200] "GET /about HTTP/1.1" 302 0 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:07:44 +0200] "GET /api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/about HTTP/1.1" 404 179 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:07:58 +0200] "GET /about HTTP/1.1" 302 0 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:07:58 +0200] "GET /api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/about HTTP/1.1" 404 179 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:08:14 +0200] "GET /about HTTP/1.1" 302 0 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:08:14 +0200] "GET /api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/about HTTP/1.1" 404 179 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:08:29 +0200] "GET /about HTTP/1.1" 302 0 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:08:29 +0200] "GET /api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/about HTTP/1.1" 404 179 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:08:44 +0200] "GET /about HTTP/1.1" 302 0 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:08:44 +0200] "GET /api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/about HTTP/1.1" 404 179 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:08:59 +0200] "GET /about HTTP/1.1" 302 0 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:08:59 +0200] "GET /api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/about HTTP/1.1" 404 179 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:09:14 +0200] "GET /about HTTP/1.1" 302 0 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:09:14 +0200] "GET /api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/about HTTP/1.1" 404 179 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:09:30 +0200] "GET /about HTTP/1.1" 302 0 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:09:30 +0200] "GET /api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/about HTTP/1.1" 404 179 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:09:45 +0200] "GET /about HTTP/1.1" 302 0 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:09:45 +0200] "GET /api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/about HTTP/1.1" 404 179 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:10:00 +0200] "GET /about HTTP/1.1" 302 0 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:10:00 +0200] "GET /api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/about HTTP/1.1" 404 179 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:10:15 +0200] "GET /about HTTP/1.1" 302 0 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:10:15 +0200] "GET /api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/about HTTP/1.1" 404 179 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:10:30 +0200] "GET /about HTTP/1.1" 302 0 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:10:30 +0200] "GET /api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/about HTTP/1.1" 404 179 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:10:46 +0200] "GET /about HTTP/1.1" 302 0 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:10:46 +0200] "GET /api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/about HTTP/1.1" 404 179 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:11:01 +0200] "GET / HTTP/1.0" 302 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.0 Safari/605.1.15" "fe80::143f:8311:c2f1:4264, 172.30.32.1"
172.30.32.2 - - [21/Oct/2023:15:11:01 +0200] "GET / HTTP/1.1" 302 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.0 Safari/605.1.15" "fe80::143f:8311:c2f1:4264, 172.30.32.1"
127.0.0.1 - - [21/Oct/2023:15:11:01 +0200] "GET /about HTTP/1.1" 302 0 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:11:01 +0200] "GET /api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/about HTTP/1.1" 404 179 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:11:01 +0200] "GET /admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/ HTTP/1.0" 200 2767 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.0 Safari/605.1.15" "fe80::143f:8311:c2f1:4264, 172.30.32.1"
172.30.32.2 - - [21/Oct/2023:15:11:01 +0200] "GET /admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/ HTTP/1.1" 200 2767 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.0 Safari/605.1.15" "fe80::143f:8311:c2f1:4264, 172.30.32.1"
127.0.0.1 - - [21/Oct/2023:15:11:09 +0200] "POST /admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/ HTTP/1.0" 302 0 "http://homeassistant.local:8123/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.0 Safari/605.1.15" "fe80::143f:8311:c2f1:4264, 172.30.32.1"
172.30.32.2 - - [21/Oct/2023:15:11:09 +0200] "POST /admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/ HTTP/1.1" 302 0 "http://homeassistant.local:8123/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.0 Safari/605.1.15" "fe80::143f:8311:c2f1:4264, 172.30.32.1"
127.0.0.1 - - [21/Oct/2023:15:11:10 +0200] "GET / HTTP/1.0" 200 20645 "http://homeassistant.local:8123/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.0 Safari/605.1.15" "fe80::143f:8311:c2f1:4264, 172.30.32.1"
172.30.32.2 - - [21/Oct/2023:15:11:10 +0200] "GET / HTTP/1.1" 200 20645 "http://homeassistant.local:8123/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.0 Safari/605.1.15" "fe80::143f:8311:c2f1:4264, 172.30.32.1"
127.0.0.1 - - [21/Oct/2023:15:11:10 +0200] "GET /xhr/header HTTP/1.0" 200 123 "http://homeassistant.local:8123/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.0 Safari/605.1.15" "fe80::143f:8311:c2f1:4264, 172.30.32.1"
172.30.32.2 - - [21/Oct/2023:15:11:10 +0200] "GET /xhr/header HTTP/1.1" 200 123 "http://homeassistant.local:8123/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.0 Safari/605.1.15" "fe80::143f:8311:c2f1:4264, 172.30.32.1"
127.0.0.1 - - [21/Oct/2023:15:11:11 +0200] "GET /about HTTP/1.0" 200 15646 "http://homeassistant.local:8123/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.0 Safari/605.1.15" "fe80::143f:8311:c2f1:4264, 172.30.32.1"
172.30.32.2 - - [21/Oct/2023:15:11:11 +0200] "GET /about HTTP/1.1" 200 15646 "http://homeassistant.local:8123/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.0 Safari/605.1.15" "fe80::143f:8311:c2f1:4264, 172.30.32.1"
127.0.0.1 - - [21/Oct/2023:15:11:16 +0200] "GET /about HTTP/1.1" 302 0 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:11:16 +0200] "GET /api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/about HTTP/1.1" 404 179 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:11:22 +0200] "GET / HTTP/1.0" 200 20645 "http://homeassistant.local:8123/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.0 Safari/605.1.15" "fe80::143f:8311:c2f1:4264, 172.30.32.1"
172.30.32.2 - - [21/Oct/2023:15:11:22 +0200] "GET / HTTP/1.1" 200 20645 "http://homeassistant.local:8123/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.0 Safari/605.1.15" "fe80::143f:8311:c2f1:4264, 172.30.32.1"
127.0.0.1 - - [21/Oct/2023:15:11:22 +0200] "GET /xhr/header HTTP/1.0" 200 124 "http://homeassistant.local:8123/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.0 Safari/605.1.15" "fe80::143f:8311:c2f1:4264, 172.30.32.1"
172.30.32.2 - - [21/Oct/2023:15:11:22 +0200] "GET /xhr/header HTTP/1.1" 200 124 "http://homeassistant.local:8123/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.0 Safari/605.1.15" "fe80::143f:8311:c2f1:4264, 172.30.32.1"
127.0.0.1 - - [21/Oct/2023:15:11:31 +0200] "GET /about HTTP/1.1" 302 0 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:11:31 +0200] "GET /api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/about HTTP/1.1" 404 179 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:11:47 +0200] "GET /about HTTP/1.1" 302 0 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:11:47 +0200] "GET /api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/about HTTP/1.1" 404 179 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:12:02 +0200] "GET /about HTTP/1.1" 302 0 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:12:02 +0200] "GET /api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/about HTTP/1.1" 404 179 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:12:17 +0200] "GET /about HTTP/1.1" 302 0 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:12:17 +0200] "GET /api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/about HTTP/1.1" 404 179 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:12:32 +0200] "GET /about HTTP/1.1" 302 0 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:12:32 +0200] "GET /api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/about HTTP/1.1" 404 179 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:12:47 +0200] "GET /about HTTP/1.1" 302 0 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:12:47 +0200] "GET /api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/about HTTP/1.1" 404 179 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:13:03 +0200] "GET /about HTTP/1.1" 302 0 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:13:03 +0200] "GET /api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/about HTTP/1.1" 404 179 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:13:18 +0200] "GET /about HTTP/1.1" 302 0 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:13:18 +0200] "GET /api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/about HTTP/1.1" 404 179 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:13:33 +0200] "GET /about HTTP/1.1" 302 0 "-" "curl/8.0.1" "-"
127.0.0.1 - - [21/Oct/2023:15:13:33 +0200] "GET /api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/admin/login/?next=/api/hassio_ingress/nCd8-Tq9MRR3XbaA19gnCCKrVRQjM4Z2A_PBxMwmUhM/about HTTP/1.1" 404 179 "-" "curl/8.0.1" "-"
Geen idee, ik gebruik dat niet maar je kan beter kijken of hier Issues · dsmrreader/dsmr-reader · GitHub ergens het probleem besproken wordt, aangezien het niet zoveel te doen heeft met de addon.
I’ve checked and I can visit the api docs of the addon just fine. Can you post a screenshot?
