Yeah sure, when i read de MQTT messages (using MQTT explorer) is see the DSMR messages.
but when i look at the entities :
Within de DSMR config:
Hey @TheCosmicGate, like Sander was saying. Do you have installed beside the DSMR reader Addon (from Sander) installed the DSMR Reader in “intergrations” ?
Okay @TheCosmicGate, I couldn’t see it in your other message but try to remove the dsmr intergration and reinstall it again.
That seems to be the solution for now. It’s working again
Anyone that has a working configuration for for DSMR Reader for Slimmelezer+ by Zuidwijk, connected via WiFi, and currently hooks directly with HA via ESPHome?
Or maybe it is not possible to connect to if from the add-on?
@marieper it’s not possible with esphome. Because DSMR Reader needs or a usb device (that shows the telegrams) or needs a telnet device. Sadly esphome doesn’t support that.
I thought that i read somewere you could flash the “slimmelezer” from Marcel with a other firmware, so it could use telnet. And then use DSMR Reader plugin (https://www.zuidwijk.com/using-esp-link/)
Not sure exactly but I thought to remember that it works with DMSR Reader, if that’s the case it could also work with the addon.
Thanks a million.
I’ll try it out, and I happen to have a spare Slimmeleze+ as I bought one extre when I beleived my original one had died.
I experience an issue, possibly related to this reported issue.
The quick and dirty solution is to restart the add-on periodically. A small blueprint is a temporary solution:
alias: DSMR reader herstart
description: ""
- platform: time_pattern
minutes: /10
condition: []
- service: hassio.addon_restart
metadata: {}
addon: 0826754b_dsmr_reader
mode: single
Bssed on the reported issue i created a new release as stability is essential. @EDouna , can you let me know if the issue is temperarly resolved with this release?
2024-04-17: DSMR Reader Add-on v 1.11.2, DSMR-reader v5.11
Changelog here
On it. Downloading and I will monitor it - I’ll keep you posted.
At first sight this seems to stabilize my situation. Further details are shared on Github. Thanks Sander!
