The zwave change works great for me. Thanks for the heads up.
This broke for me in 0.110 when in either vertical or horizontal stack card. I posted to git here
Anyone else have, or more importantly not have that issue? Or find a workaround that still allows stacking?
Since the card is no longer maintained, youâll have to fix it yourself.
Missed that it wasnât maintained, thanks for that info.
The native card should give you the same features than this card since 0.103, have you tried using it?
I couldnât get it to show the fan control, maybe I missed a setting. The Simple-Thermostat works well though, and I can add other sensors which is nice as I have a flakey thermostat who does not report fan status correctly.
Oh ok yeah the fan control is something I implemented on this card, it does not come as part of the native card.
Hey there I am new to this so if this isnt the right place I am sorry, but I currently have a card setup to use my phillips hue temp sensor and tells my smart plug to turn my window ac on or off, but now I wanna do a dual card so I can have a smart plug connected to a heater as well for cold days.
This is what I have so far
cards:
* type: custom:dual-thermostat
entities:
* entity: climate.air_conditioner
type: cool
* entity: climate.downstairs_heat
type: heat
fan_control: true
min_slider: 60
max_slider: 80
It says No card type found
I also added this /community_plugin/dual-thermostat/dual-thermostat.js to the lovelace Resource config page
Also this is what I added to my configuration.yaml
climate:
* platform: generic_thermostat
name: Air Conditioner
heater: switch.bedroom_air_conditioner
target_sensor: sensor.hue_motion_sensor_1_temperature
min_temp: 15
max_temp: 28
ac_mode: true
target_temp: 17
cold_tolerance: 0.3
hot_tolerance: 0
min_cycle_duration:
seconds: 5
keep_alive:
minutes: 3
initial_hvac_mode: âoffâ
away_temp: 16
precision: 0.1
heater: switch.bedroom_heater
min_temp: 15
max_temp: 28
ac_mode: false
target_temp: 17
cold_tolerance: 0.3
hot_tolerance: 0
min_cycle_duration:
seconds: 5
keep_alive:
minutes: 3
away_temp: 16
precision: 0.1
I am able to get them to work in separate cards just not all in one with the âautoâ function
Is this card still working in HA? My issue is my cooling and heating are 2 different units and I want to combine them into one thermostatâŚ
Thank you!
