Huh ???
Not sure then … but I have a sensor : -
sensor.cert_expiry_timestamp_home_assistant_io
Which does not appear in any of my yaml config so I just assumed it turned up with DuckDNS
Huh ???
I certainly don’t. Maybe because of the type of your installation (Home Assistant IO)? But doesn’t sound too likely, I guess…
I run three instalations, one core, but primary and major test are both HassOS (one NUC one Pi4) both HassOS have this sensor.
You can create such an sensor
Thanks for this, I don’t remember doing it but I must have
Somebody suggested that above already, but for some reason I cannot install that integration (see here)… Thanks anyways for trying to help!
