no wireguard.
hmmm, where is Settings ? → Home Assistant Settings > General (scroll right down to the near the bottom) > External and Internal URL in there
G
no wireguard.
G
Sorry it’s called Configuration not settings. In the left side bar in the web interface.
ahhhh, found it, this setting is actually pulled from configuration.yml, I had external commented out.
# external_url: "https://<new domainname>.com" # dns via cloudflare + lets_encrypt cert
# external_url: "https://<old domainname>.ddnsfree.com:8124" # via nginx ssl proxy
internal_url: "http://172.16.10.21:8123"
and the search continues…
Could you sanitise the logged network events you are seeing and paste an example here?
U:ll at times have a string of these right after each other.
This comes out of Services / Siricata / alerts on my LAN interface, I will have similar alerts on the WAN where it shows it going out my GW to Duckdns.
G
And you have checked the Configuration / Integrations page for the certificate expiry integration?
yes, no certificate expiry integration.
G
