Hey all,
HA: 0.103.5
DeConz: 5.0 (Hassio add on)
Not sure if im misunderstanding how this works, however im seeing 3 deconz groups in HA but i only have 2 in DeConz?
2 are a duplicate (red marking) and do the same thing (control those lights)
ive tried to remove the integration and add back in again but same issue.
i cant see RWL021 3 anywhere in DeConz
in DeConz i only have 2 groups
kurtj
(Kurt)
January 3, 2020, 9:18pm
2
Have you ever removed those groups from Deconz and created them again?
I think you and I have the same issue:
As per suggestion by @Robban in this thread:
I looked for remotes that stayed behind, and indeed I found one. However after deleting, deconz.device_refresh, reboot my HA, still no avail…
EDIT:
Since deconz is running in a container, I can’t really install the full deconz app, short of installing a second Rpi. So I decided to query the Rest api… I can’t start postman either so curl had to do…
~ $ curl "http://172.30.33.0:40850/api/xxxxxxxxxxxxx/groups" | jq '.' | grep name
% Total % …
Robban
January 3, 2020, 9:33pm
3
They are groups created by remotes. In this case a hue dimmer remote
