Just released 2023.4.26.1 which fixes an issue with 2 entities showing up when requesting a station by id.
There is also a new feature: the images (original and edited) are send through mqtt to dgp/[station_id] as a url encoded string. This way you are able to review the images that where, until now, only available internally.
DGP == OCR on images provided by https://directlease.nl/tankservice/. The image that is being scanned to get the data from, that image is now available through MQTT.
So yeah, the brand is send with the image so you are not totally wrong. It is not directly available, but you could write it to disk and present it somewhere, like in your messages. This is something the addon could also do, but i am not sure if they should written them to disk to be available.
Hoi! I’m curious to try out this add-on, but I’m afraid to install it if it could potentially crash my HA instance. Since the known issues report that “On an RPi3 the installation could crash the system, a retry of the installation should fix it”. I’m running HA Core 2022.12.8 on an RPi 3B+.
