I explicitly deleted the buienradar external lib before upgrading HA to 0.47; It was added / installed again as soon as I started it.
I also noticed the error, but the sensor component worked as expected
The weather component, did not work as it did b efore the update; I traced that back to this, can you see if this change works for you as well ? (weather/buienradar.py in method async_setup_platform)
The sensor component works for me now as well. I suppose I was just to impatient, I waited a minute or two before I posted but nothing appeared. When I looked this morning however, there was data.
Regarding the weather component, I will try that this afternoon and get back to you.
I tried the weather component fix and I think that did the trick, no more errors! However, funny thing, if I go to check the entity state, it is listed as weather.br_unknown_station. It does have a correct weather state though, so I guess it’s just a naming thing?
I checked as well; you are right: it shows as weather.br_unknown_station IF you do not specify a name for the weather component in the configuration…
If no name is specified, the weather component tries to specify its name as “br_[stationname]”; however, at the moment the sensor is created, no data has been fetched yet, so the stationname is unknown at that moment in time. As soon as data is fetched, the name gets updated, however the sensor was already created and its entity name defined…
If you specify the name of the component in the configuration, it will reflect that in the entity name:
2017-06-21 15:30:25 INFO (MainThread) [homeassistant.loader] Loaded weather.buienradar from homeassistant.components.weather.buienradar
2017-06-21 15:30:25 INFO (MainThread) [homeassistant.components.weather] Setting up weather.buienradar
File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/weatherbuienradar.py", line 83, in condition
File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/sensor/buienradar.py", line 275, in condition
from buienradar.buienradar import SYMBOL
ImportError: No module named 'buienradar'
yes it shoudl show something…
However it all depends on the data for the selected weatherstation (voorschiten) in your case.
In my case, I had to force the buienradar sensor to not use the nearest station, since it was way closer to sea than I am, which has a big influence on temperature, etc. So I forced it to use lopik for me. Of course, if it rains right now, it should show precipitation, but it all depends on teh data you get from the selected weatherstation (if it does not rain there, it will show no rain, even though it rains outside with you)
Thats indeed a nice option too, but i would like to have it as a number. That way you can somewhat determine the intensity of the sun. Which i could use to trigger my sunscreen. “UV index 1” with 20 degrees means that it won’t really heat up my house through the windows, if this goes to 5+ it will at 20 degrees, something like that. I am also trying to just use difference inside and outside too. (and to be alerted when i have to use sunscreen for the kids if they go to school)
Changed my station to “Schiphol” lets see if i can see some precipitation. Is there a easy way to see which station is the closest?
I updated the documentation of the weather component; if you check the component documentation you can see why this is and what you could do to change this behavior
Your “and this:” is empty, but indeed that is where i checked, but i don’t know “all” the places, hence a graph would be nice, but i’ve taken “Schiphol” to test, since that must surely have rain meters.
2017-06-25 20:35:42 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.weather.buienradar. Make sure all dependencies are installed
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/loader.py", line 141, in get_component
module = importlib.import_module(path)
File "/usr/lib/python3.4/importlib/__init__.py", line 109, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 2254, in _gcd_import
File "<frozen importlib._bootstrap>", line 2237, in _find_and_load
File "<frozen importlib._bootstrap>", line 2226, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 1200, in _load_unlocked
File "<frozen importlib._bootstrap>", line 1129, in _exec
File "<frozen importlib._bootstrap>", line 1471, in exec_module
File "<frozen importlib._bootstrap>", line 321, in _call_with_frames_removed
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/weather/buienradar.py", line 16, in <module>
from homeassistant.components.sensor.buienradar import (
ImportError: cannot import name 'BrData'
2017-06-25 20:35:42 ERROR (MainThread) [homeassistant.loader] Unable to find component weather.buienradar
