DWD global weather (warning) integration
I’m creating a html mail and send it via smtp.
  - platform: dwd_weather_warnings
    region_name: Kreis und Stadt Würzburg
    sensors:
      dwd_warn_count:
        value_template: '{{ states.sensor.dwdweatherwarnings_current_warning_level.attributes.warning_count }}'
automation:
  - alias: send_dwd_warning
    initial_state: True
      - platform: state
        entity_id: sensor.dwd_warn_count
      - platform: state
        entity_id: sensor.dwdweatherwarnings_current_warning_level
      condition: template
      value_template: '{{ (trigger.to_state.state != trigger.from_state.state) and trigger.to_state.state | int > 0 }}'
      - condition: state
        entity_id: script.send_dwd_warn_mail
        state: 'off'
      - service: homeassistant.turn_on
script:
  send_dwd_warn_mail:
      - delay:
          seconds: 10
      - service: notify.ios_iphone
          title: "DWD Wetterwarnung!"
          message: "Aktuelle Warnung kommt per Mail."
      - service: shell_command.get_warn_image
      - delay:
          minutes: 1
      - service: notify.gmail_smtp
        data_template:
          title: 'DWD Wetterwarnung!'
          message: ' '
            images:
            html: >
              <!DOCTYPE html><html><head><style>a, h3, h4 {font-family: arial;}</style></head><body>
              <h3>{{ states.sensor.dwdweatherwarnings_current_warning_level.attributes.region_name }}</h3>
              {% if states.sensor.dwdweatherwarnings_current_warning_level.attributes.warning_1_headline is defined %}
                <h3>{{ states.sensor.dwdweatherwarnings_current_warning_level.attributes.warning_1_headline }}</h3>
                Warnstufe: {{ states.sensor.dwdweatherwarnings_current_warning_level.attributes.warning_1_level }}
                <br>
                Von: {{ as_timestamp(states.sensor.dwdweatherwarnings_current_warning_level.attributes.warning_1_start) | timestamp_custom("%a %d.%m.%Y %H:%M",true) }}
                <br>
                Bis: {{ as_timestamp(states.sensor.dwdweatherwarnings_current_warning_level.attributes.warning_1_end) | timestamp_custom("%a %d.%m.%Y %H:%M",true) }}
                <br>
                {{ states.sensor.dwdweatherwarnings_current_warning_level.attributes.warning_1_description }}
                <br>
                <br>
              {% if states.sensor.dwdweatherwarnings_current_warning_level.attributes.warning_2_headline is defined %}
                <h3>{{ states.sensor.dwdweatherwarnings_current_warning_level.attributes.warning_2_headline }}</h3>
                Warnstufe: {{ states.sensor.dwdweatherwarnings_current_warning_level.attributes.warning_2_level }}
                <br>
                Von: {{ as_timestamp(states.sensor.dwdweatherwarnings_current_warning_level.attributes.warning_2_start) | timestamp_custom("%a %d.%m.%Y %H:%M",true) }}
                <br>
                Bis: {{ as_timestamp(states.sensor.dwdweatherwarnings_current_warning_level.attributes.warning_2_end) | timestamp_custom("%a %d.%m.%Y %H:%M",true) }}
                <br>
                {{ states.sensor.dwdweatherwarnings_current_warning_level.attributes.warning_2_description }}
                <br>
                <br>
              {% if states.sensor.dwdweatherwarnings_current_warning_level.attributes.warning_3_headline is defined %}
                <h3>{{ states.sensor.dwdweatherwarnings_current_warning_level.attributes.warning_3_headline }}</h3>
                Warnstufe: {{ states.sensor.dwdweatherwarnings_current_warning_level.attributes.warning_3_level }}
                <br>
                Von: {{ as_timestamp(states.sensor.dwdweatherwarnings_current_warning_level.attributes.warning_3_start) | timestamp_custom("%a %d.%m.%Y %H:%M",true) }}
                <br>
                Bis: {{ as_timestamp(states.sensor.dwdweatherwarnings_current_warning_level.attributes.warning_3_end) | timestamp_custom("%a %d.%m.%Y %H:%M",true) }}
                <br>
                {{ states.sensor.dwdweatherwarnings_current_warning_level.attributes.warning_3_description }}
                <br>
                <br>
              {% if states.sensor.dwdweatherwarnings_current_warning_level.attributes.warning_4_headline is defined %}
                <h3>{{ states.sensor.dwdweatherwarnings_current_warning_level.attributes.warning_4_headline }}</h3>
                Warnstufe: {{ states.sensor.dwdweatherwarnings_current_warning_level.attributes.warning_4_level }}
                <br>
                Von: {{ as_timestamp(states.sensor.dwdweatherwarnings_current_warning_level.attributes.warning_4_start) | timestamp_custom("%a %d.%m.%Y %H:%M",true) }}
                <br>
                Bis: {{ as_timestamp(states.sensor.dwdweatherwarnings_current_warning_level.attributes.warning_4_end) | timestamp_custom("%a %d.%m.%Y %H:%M",true) }}
                <br>
                {{ states.sensor.dwdweatherwarnings_current_warning_level.attributes.warning_4_description }}
                <br>
                <br>
              <a href="http://www.dwd.de/DWD/warnungen/warnapp_gemeinden/json/warnungen_gemeinde_map_bay.png">Aktuelle Warnkarte</a>
              <br>
              <img class="rounded" alt="Warnkarte" src="cid:warnungen_gemeinde_map_bay.png" /></body></html>
shell_command:
  get_warn_image: 'wget http://www.dwd.de/DWD/warnungen/warnapp_gemeinden/json/warnungen_gemeinde_map_bay.png -q -O warnungen_gemeinde_map_bay.png'
This generates a mail like this.
