uowis
(Uowis)
42
thanks it’s good for me, now i have make it with date :
type: custom:config-template-card
entities:
- input_datetime.energy_viewer
variables:
DAY: |
var targetDate = states['input_datetime.energy_viewer'].state;
var myDate = states['input_datetime.energy_viewer'].state.split("-");
var newDate = new Date( myDate[2], myDate[1] - 1, myDate[0]);
var offSet = Math.ceil((Date.parse(targetDate) - Date.now()) / 86400000)
var sign = offSet < 0 ? "" : "+";
sign + offSet + "d" ;
TITLE: >
const options = { weekday: 'long', year: 'numeric', month: 'long', day:
'numeric' };
new Date(targetDate).toLocaleDateString("fr", options);
card:
style: |
#header__title {
text-align: center;
type: custom:apexcharts-card
Giggi
44
i have also make make it with date and read data from influxdb if anyone needs it
type: vertical-stack
cards:
- type: entities
entities:
- entity: input_datetime.chart_datetime
- entity: input_select.chart_span
- type: custom:config-template-card
entities:
- input_datetime.chart_datetime
- input_select.chart_span
variables:
DAY: >
var targetDate = states['input_datetime.chart_datetime'].state;
var targetDate_ms = new Date(targetDate);
var Difference_In_ms = Date.now() - targetDate_ms
var seconds = Math.floor((Difference_In_ms / 1000) % 60)
var minutes = Math.floor((Difference_In_ms / (1000 * 60)) % 60)
var hours = Math.floor((Difference_In_ms / (1000 * 60 * 60)) % 24)
var days = Math.floor((Difference_In_ms / (1000 * 60 * 60 * 24)))
var result = days < 0 ? "-1d" :
"-"+days+"d"+"-"+hours+"h"+"-"+minutes+"m";
result ;
span: states['input_select.chart_span'].state
card:
graph_span: ${span}
span:
start: minute
offset: ${DAY}
yaxis:
- id: first
decimals: 0
- id: second
opposite: true
series:
- entity: input_text.dummy
yaxis_id: first
type: line
extend_to: false
group_by:
func: avg
duration: 30min
data_generator: |
var params = new URLSearchParams({
db: "home_assistant",
p: "influxdbpasswort",
u: "influxdbuser",
q: "SELECT \"value\" FROM \"W\" WHERE \"entity_id\" = 'momentanp' AND time >= '" + start.toISOString() + "'AND time <= '" + end.toISOString() + "'"
var myInit = { method: 'GET',
headers: {
'Accept': 'application/json',
mode: 'cors',
cache: 'default'
const request = async () => {
var result = [];
const response = await fetch('http://192.168.178.57:8086/query?' + params, myInit)
const json = await response.json();
if (json["results"] && json["results"][0] && json["results"][0]["series"] && json["results"][0]["series"][0] && json["results"][0]["series"][0]["values"]) {
for(var val of json["results"][0]["series"][0]["values"]) {
result.push([new Date(val[0]), val[1]]);
return result;
return request();
update_interval: 5m
KKlausl
(KKlausl)
45
Hey and WOW, that really works superb! Thank you for your efforts!! I have two Questions:
Could it be possible to show the config-template-card AFTER the Data?
Is it possible to use just one config-template-card for two other Data-Cards, but the second Data is “outside” the vertical stack?
Sorry to bother you - Im really new here…
