I added it manually in config. I am not aware that it can auto pick it up.
Can you share your configuration.yaml for the Dyson fan??
Similar, all was working on 0.114.2, rebooted due to a HACS upgrade, and now Dyson configuration is invalid. All are manually defined within config.
I should note that I have 5 fans. I did receive a notification that one has detected a fault. When this occurs, if I do not power cycle it, and reboot HA, 4 would come back, and the trouble unit would become unavailable. No longer the case. Not sure if this has anything to do with it.
Update, if one device goes offline (with a Dyson reported fault), the entire component does not load with a HA restart. Removing the faulty unit in configuration.yaml, allows the component to reload with the remaining devices.
I have a Dyson Vacuum cleaner, the integration hasn’t been working for weeks.
But happy to report that mine started working again in 114.4.
Thanks to the Boffins for fixing this.
I wonder how long before Dyson make changes and break it again!
I just tried the 114.4 update , no luck on my end
