It really works, great. thank you very much.
I also have the same problem if I am not sending a message for a long time, I need to resend the code “join soap-bee”.
But glad to be able to work, and very grateful to you and @Tomer_Klein
you Sir, have made my day!
thanks, your solution is working.
thanks Tomer for a great component
And how can i use this with an automation now?
cool, a whatsapp “integration”, …
it is possible to send images also ? for a camera snapshot?
please add an automation example.
Is it now possible to send messages which don’t match a predefined template?
I am stuck with this error? Any help would be appreciated thanks
error: Unable to create record: Twilio could not find a Channel with the specified From address
I completed the procedure but I am not even able to find a service under notify in the name of what i have put in config to sent message. Why is it so?
If there is no one message sent after a few days, it’s neccessary to send code to twilio again to start messages working. This is because free trial version close connection after a few days if no messages sent. For use it without breaking connection messages should be sent using template described in twilio service. So, I use “Your message code is MESSAGE”. It’s allow me to not worry if there is no message sent in a few days.
Could you explain what do you mean ?
As you said, I should start it again by sending approving code like a first time (sending “join soap-bee” every day).
So, if I’ll send the “your message code is MESSAGE” message, I done with sending any message ?
Something like that. As @gerard33 mentioned and I experienced, if there is no messages sent some time - messages stop sending and you should send approve code to twillio again. But when I started to send messages formatted by template, messages are sent over a month already without problems.
Or you can switch to paid tariff.
Thanks, I’ll try that.
Cool, thanks for letting us know.
These are the 3 available templates btw:
Your {{1}} code is {{2}}
Your appointment is coming up on {{1}} at {{2}}
Your {{1}} order of {{2}} has shipped and should be delivered on {{3}}. Details: {{4}}
I am using:
Your HA code is -> <message_here>
Hi
Is it working for you ?
Maybe I don’t really understand what should I do to avoid sending the messages each day.
Regards,
Alex.
Yeah it works here when you use the templates as mentioned above.
In that case you don’t need to send a message every that as using that template the message will always arrive.
You can for example use this message and you will see it arrives in Whatsapp:
Your HA code is this is a test
Just replace the
this is a test
part with the actual message you want to send, but make sure it always starts with
Your HA code is
Thanks @gerard33
The following is my code, could you please let me know if this is you are suggesting ?
import appdaemon.plugins.hass.hassapi as hass
import datetime
class AutoTurnOnOffOutdoorLightes(hass.Hass):
def initialize(self):
# Create a time object for 18:30
runtime_lights_on = datetime.time(18, 30, 0)
# Schedule a daily callback that will call turn_on_outdoor_lights() at 18:30 every night
self.run_daily(self.turn_on_outdoor_lights, runtime_lights_on)
def turn_on_outdoor_lights(self, entity):
self.log("Turned on outdoor lights at 18:30 every night.")
self.call_service("notify/whatsapp", message = "Your HA code is - Turned on outdoor lights.", target = "+972549123456")
self.turn_on("group.outdoor_lights")
Yeah that should work indeed.
Thanks,
I’ll check it.
