I used MQTT instead of doing things through HA. I use Node-Red for my automations, so it was easier and actually works. You can trigger on zwave/<node name>/32/0/currentValue
to update the status indicator value in HA when deactivating. You can trigger on zwave/<node name>/43/0/sceneId
for activation. I then read the indicator LEDs at zwave/<node name>/135/0/value
and do some binary math to see what changed from the previous indicator state.
I also have this scene controller and was using blakeblackshear’s custom component. I got the ZwaveJS events working on button press, but did anyone ever figure out how to handle refreshing and updating the indicator or handling turning off a button?
Alternatively, does anyone have enough python knowledge to take a shot at updating the custom component for ZwaveJS?
I’ve seen a lot of articles on this device and I got a bit lost on which solutions actually worked. I have a bunch of these around my house (probably 10).
I just migrated to ZwaveJS and i’m looking to see what the current functionality is for these devices.
- What is the best current path to trigger an indicator from HA?
- What is the best way to use a physical button press to trigger something in HA?
Thank you
