The unmute and volume set has no effect on the gen 3 dot. All the other actions work, play radio, announce etc.
It is at volume 3 via a voice request (“Alexa, set volume 3”), and I can hear it playing. This does not reflect at all in the entity’s state.
Hi there, I’m getting problems with last version:
-HA 0.98.1 on Docker
- Alexa Media Player 2.0.1
When I restart HA after upgrade custom_component it ask me about captcha. .Then I clic on confirm but I get this:
Error calling service configurator/configure . get
and no success addin media_players.
at log I get this
2019-09-01 10:26:35 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.139947504184528] get
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 130, in handle_call_service
connection.context(msg),
File "/usr/src/homeassistant/homeassistant/core.py", line 1235, in async_call
await asyncio.shield(self._execute_service(handler, service_call))
File "/usr/src/homeassistant/homeassistant/core.py", line 1260, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/components/configurator/__init__.py", line 235, in async_handle_service_call
await self.hass.async_add_job(callback, call.data.get(ATTR_FIELDS, {}))
File "/config/custom_components/alexa_media/__init__.py", line 153, in configuration_callback
login, callback_data)
File "/config/custom_components/alexa_media/__init__.py", line 143, in setup_platform_callback
await login.login(data=callback_data)
File "/usr/local/lib/python3.7/site-packages/alexapy/alexalogin.py", line 306, in login
headers=self._headers)
File "/usr/local/lib/python3.7/site-packages/aiohttp/client.py", line 466, in _request
ssl=ssl, proxy_headers=proxy_headers, traces=traces)
File "/usr/local/lib/python3.7/site-packages/aiohttp/client_reqrep.py", line 286, in __init__
self.update_host(url)
File "/usr/local/lib/python3.7/site-packages/aiohttp/client_reqrep.py", line 340, in update_host
raise InvalidURL(url)
aiohttp.client_exceptions.InvalidURL: get
Notify is not working, I used this (earlier versions it works)
alexa_announce_example:
alias: Alexa Announce
sequence:
- data:
method: all
type: announce
message: Hello
target: media_player.s_echo_dot
service: notify.alexa_media
but where you place it on automations?
into the scripts…
In the Alexa Media player the “Text to speak” option is not working.
So frustrating to have things configured and loose it in a Update.
but my problem is that I can’t register devices because captcha fails
Fixed downgrading to 1.4.1 registering and upgrading to 2.0.1
Downgrade in v1.4.1, now no more problems.
So in the end, I cannot upgrade to 0.98.1 right? I’m on 0.97.1 with Alexa 1.4.1 and would like to Upgrade hassio. But as I noticed on a Facebook forum, 98.1 looses the connect to 1.4.1 So Alexa has to be upgraded as well. But then I will face the problems described above🤔
Now I’m uncertain…
Since the last update I’m facing a new issue.
Alexa Media isn’t able to start after a restart of ha. If this persisted notification appears I need to restart the hole system. After that Alexa media works as before.
This is a new issue I never had in former versions.
Does anyone else have the same issue?
PS: will be able to post the logs when this error happens the next time
Also I have this issue, maybe it’s somehow related:
I’ve also raised an issue regarding this, but do you have any idea why version 2.0.1 is failing to start up for me (on Home Assistant 0.98.1) with this error:
Cannot connect to host alexa.amazon.co.uk:443 ssl:True [SSLCertVerificationError: (1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1056)’)]
I rolled back to 1.4.1 and it started working again.
0.98.1 and 1.4.1. works well on my system
HA 0.98.1 and Alexa Media 2.0.1 working great here
I also get this error.
Could you share the link to that issue?
Here is the issue:
But I have now been able to solve the problem. I ran the following commands:
sudo apt-get update
sudo apt-get install ca-certificates
sudo update-ca-certificates
(The third command may not be necessary)
The issue is that v1.4.1 didn’t validate the certificate, but v2.0.0 and later do. The ca-certificates package contains the valid Certificate Authorities and, without that, it isn’t possible to do that validation.
Can you confirm that device is updating besides the volume changes? Will need logs to debug further.
Would need debug logs to help further (I know you did the workaround so in the future when the cookie expires you may run into this again.)
The stock HA UI never worked for TTS for this component. If you mean outside the UI, please file a bug report.
While I get it’s frustrating, we do warn you with the release post above that mentioned things may break. Also, when the major version number changes that normally means something major may have changed so expect bugs.
Link. Short answer is make sure you have local certs installed. It’s likely a system config issue. We previously ignored it if the system couldn’t check the Amazon SSL cert in 1.4.0. For security reasons, we now don’t ignore it.
I’m running hassio. How can I install local certs?
RESOLVED!
Watchtower updated my HA to version 0.98.2 and I now have the volume functionality again.
Thanks again for a lovely component.
Yes, everything else is updating and reacting as expected. I even redid the Pickle file.
TTS, and selecting radio stations has no problems.
The basic logs:
2019-09-02 08:58:24 INFO (SyncWorker_9) [homeassistant.loader] Loaded alexa_media from custom_components.alexa_media,
2019-09-02 08:58:24 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.,
2019-09-02 08:58:24 INFO (SyncWorker_18) [homeassistant.loader] Loaded alexa from homeassistant.components.alexa,
2019-09-02 08:58:31 INFO (MainThread) [homeassistant.setup] Setting up alexa_media,
2019-09-02 08:58:31 INFO (MainThread) [custom_components.alexa_media] ,
alexa_media,
https://github.com/custom-components/alexa_media_player/issues,
2019-09-02 08:58:31 INFO (MainThread) [custom_components.alexa_media] Loaded alexapy==1.0.1,
2019-09-02 08:58:34 INFO (MainThread) [homeassistant.setup] Setting up alexa,
2019-09-02 08:58:34 INFO (MainThread) [homeassistant.setup] Setup of domain alexa took 0.0 seconds.,
2019-09-02 08:58:41 WARNING (MainThread) [homeassistant.setup] Setup of alexa_media is taking over 10 seconds.,
2019-09-02 08:58:43 INFO (MainThread) [homeassistant.setup] Setup of domain alexa_media took 12.0 seconds.,
2019-09-02 08:58:43 INFO (MainThread) [homeassistant.components.notify] Setting up notify.alexa_media,
File "/config/custom_components/alexa_media/notify.py", line 102, in targets,
2019-09-02 08:59:29 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.alexa_media,
2019-09-02 08:59:29 INFO (MainThread) [homeassistant.components.notify] Setting up notify.alexa_media,
2019-09-02 08:59:29 INFO (MainThread) [homeassistant.components.alarm_control_panel] Setting up alarm_control_panel.alexa_media,
2019-09-02 08:59:29 INFO (MainThread) [homeassistant.components.switch] Setting up switch.alexa_media
I did however note this in the HA Developer Tools - Info section.
Log Details (ERROR)
Mon Sep 02 2019 08:58:43 GMT+0200 (South Africa Standard Time)
Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/notify/__init__.py", line 122, in async_setup_platform
if hasattr(notify_service, "targets"):
['devices']['media_player'].items()):
KeyError: 'devices'
Hi all,
I’ve got this error occurring more than 200 times in less than 5 minutes:
File "/usr/src/homeassistant/homeassistant/components/alexa/state_report.py", line 45, in async_entity_state_listener
hass, smart_home_config, alexa_changed_entity
File "/usr/src/homeassistant/homeassistant/components/alexa/state_report.py", line 103, in async_send_changereport_message
response_json = json.loads(response_text)
File "/usr/local/lib/python3.7/json/__init__.py", line 348, in loads
return _default_decoder.decode(s)
File "/usr/local/lib/python3.7/json/decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/local/lib/python3.7/json/decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
Alexa Media version 2.0.1
HA version 0.98.2
Same issue and same versions of HA and AMP like Sunny.
Moreover (or related), when I click ‘confirm’ in the Alexa Media Player persistent notification:
‘Failed call to service configurator/configure . get’
System Log:
19-09-02 09:11:19 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
Log:
get
11:20 custom_components/alexa_media/__init__.py (ERROR) - message first occured at 11:17 and shows up 2 times
Thank you
SoL
