Hi all,
the configuration form is empty. Any advice please?
HA: 0.97.2
Alexa_media: 2.2.1
Logs:
grep alexa home-assistant.log | less
2019-09-24 10:50:12 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for alexa_media which has not been tested by Home Assistant. This component might cause stability problems
, be sure to disable it if you do experience issues with Home Assistant.
2019-09-24 10:50:15 DEBUG (MainThread) [homeassistant.bootstrap] Setting up {'device_tracker', 'tplink', 'hue', 'onboarding', 'cloud', 'ssdp', 'tts', 'input_boolean', 'logbook', 'zone', 'input_datetime', '
frontend', 'script', 'websocket_api', 'person', 'lovelace', 'config', 'sensor', 'system_health', 'met', 'webhook', 'history', 'vacuum', 'sun', 'updater', 'tuya', 'auth', 'automation', 'duckdns', 'group', '
alexa_media', 'default_config', 'http', 'zeroconf', 'mobile_app', 'api', 'map'}
2019-09-24 10:50:17 INFO (MainThread) [homeassistant.setup] Setting up alexa_media
2019-09-24 10:50:17 INFO (MainThread) [homeassistant.setup] Setup of domain alexa_media took 0.0 seconds.
2019-09-24 10:50:17 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=alexa_media>
2019-09-24 10:50:17 DEBUG (MainThread) [custom_components.alexa_media.config_flow] Creating new login
2019-09-24 10:50:17 DEBUG (MainThread) [alexapy.alexalogin] Trying to load pickled cookie from file /home/homeassistant/.homeassistant/[email protected]
2019-09-24 10:50:18 DEBUG (MainThread) [alexapy.alexalogin] cookie loaded: <class 'dict'> {'session-id': '260-3434880-8246605', 'session-id-time': '2197537201l', 'ubid-acbde': '262-1885261-7052166', 'sessi
on-token': 'YY1Whb6Bye5o6EZW3qwoxCiU7sDEVp1lO7b4tPFoGZ+MRiTWraEfWoUFSUt5A+cM5GTCwPbmCRoBdzsLGwp7EDEZTj/MsBZpWr590mmg6DsDMGZj9MjtM8LEtkRMsJLpaPPACDknCifkIE+qMPfZGMqGwkWU4tg/j25eQwh7ekKnslmdpJ4ac2sXJkjQcvTwx
taRByiEJmIejx7pgR78N6SfRINU8KUO1MtXdYkwrno=', 'x-acbde': 'ic93wP3hoyKhJXZXmgs0mnbUXsUft7XK4ze@@GQ5lJ?xwhDtLaoAl1P7vBz4WVTl', 'at-acbde': 'Atza|IwEBIC0DERRmhMwvGN8xwiUnzWvwq3Y44FFC8H3utjRqqJ9spWsgJxvonPEXXd
woKC0mJnQzb1UE8QbzYzE0r64TNbk-wela2pEwRwu0CpkW10jTtb_m325B4KPZDF0wCWvtzAZ_7X8eoW4E9187ZYU-463QMhVF1BG9AdyNMHsVdvnCorVet10kq1XW2HfWDmRjLorKkebT4Tt1XE4hqoCgd5GEAN9e1_ya0EnajvWc3G0i9su_EwoEEbENyydgRCL-ts8gkVI
ILoNvf1dWnB08B-SpZ_-K0N_ecEuzPSEggr1f_9pJvMW-VxCXlloFpW5bLqJw0c5FyxTGuBmqqnmJahLL3feCK37pfhs5ZXGZa7WXQ2SCitm4uHOR1VOoIGmYSdZSWCBWYo0LIJNny8DI-mjw', 'sess-at-acbde': 'AqKzEQ5i1GsUwd7hL3LQrpwhFDhY5ojw6LBXtKN
X6n4=', 'sst-acbde': 'Sst1|PQHmkMQztRx_4Wun6I4H1aRBC7YVjV7hl0iAoVbiJP3Pe50OvuvBO-XBSIQEheQtIdff6k2SvUUZKxj2vSxsbx4h9egC8kzn2BqD7omRjX23Yz6nFjzFxqDKJk9uQo9k4J-Ii_5XKbGSVbj2II4Ijb1RchwxR58L3uf_kYoZXGs5lol8YN
m0sunLYVtpmeav0k5XgIniSVbsxmhEYg8EX-HyMUI-xdsBNkl4ljBs9r1uPJn4O6nA6-X6e2_TYXuMReruWvEK8mula4jKjby4X-hZ9H7WHSBFAWoduh0bCwIIvUa5c4PidjQgYtpexWlwL-rwUtqwKNzq7ZgscCh8t3WxkQ', 'csrf': '568438813'}
2019-09-24 10:50:20 DEBUG (MainThread) [alexapy.alexalogin] Found dict cookie
2019-09-24 10:50:20 DEBUG (MainThread) [alexapy.alexalogin] Loaded 9 cookies
2019-09-24 10:50:22 DEBUG (MainThread) [alexapy.alexalogin] GET: redirected from
https://alexa.amazon.de/api/bootstrap
https://www.amazon.de/ap/signin?showRmrMe=1&openid.return_to=https://alexa.amazon.de/api/bootstrap&openid.identity=http://specs.openid.net/auth/2.0/identifier_select&openid.assoc_handle=amzn_dp_project_dee
_de&openid.mode=checkid_setup&openid.claimed_id=http://specs.openid.net/auth/2.0/identifier_select&openid.ns=http://specs.openid.net/auth/2.0& with
2019-09-24 10:50:22 DEBUG (MainThread) [alexapy.alexalogin] Not logged in: An exception of type ContentTypeError occurred. Arguments:
2019-09-24 10:50:22 DEBUG (MainThread) [alexapy.alexalogin] No valid cookies for log in; using credentials
2019-09-24 10:50:23 DEBUG (MainThread) [alexapy.alexalogin] GET: redirected from
https://www.amazon.de/ap/signin?showRmrMe=1&openid.return_to=https://alexa.amazon.de/&openid.identity=http://specs.openid.net/auth/2.0/identifier_select&openid.assoc_handle=amzn_dp_project_dee_de&openid.mo
<CIMultiDictProxy('Host': 'www.amazon.de', 'User-Agent': 'Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/68.0.3440.106 Safari/537.36', 'Accept': 'text/html,applicati
on/xhtml+xml, application/xml;q=0.9,*/*;q=0.8', 'Accept-Language': '*', 'Referer': 'https://www.amazon.de/ap/signin?showRmrMe=1&openid.return_to=https://alexa.amazon.de/api/bootstrap&openid.identity=http:/
/specs.openid.net/auth/2.0/identifier_select&openid.assoc_handle=amzn_dp_project_dee_de&openid.mode=checkid_setup&openid.claimed_id=http://specs.openid.net/auth/2.0/identifier_select&openid.ns=http://specs.openid.net/auth/2.0&', 'Accept-Encoding': 'gzip, deflate', 'Cookie': 'session-token="Bc+yuSiMMeXt0viKO37PRYI+5JVQnTjQOV8V924WLiIKVZilTNcAY7/Ot2qAIWY9/wylx5wvpP4bj+oLu/5WNVAbLmd6IZWNkbtj/99R6Gx3VN/r4BkzmUsxpwKoOMB9p356uW9ayRzPemKmRmyllQ8822SdXrCbZwhtFN4u4P4z8hRNCs+wpzde2OUrZi3aFSWHQhxK3Hh4ufrQbhU/vwEBKsmPmxUOslj+wiSYmH4="; ubid-acbde=262-1885261-7052166')>
2019-09-24 10:50:23 DEBUG (MainThread) [alexapy.alexalogin] Processing https://www.amazon.de/ap/signin?showRmrMe=1&openid.return_to=https://alexa.amazon.de/&openid.identity=http://specs.openid.net/auth/2.0/identifier_select&openid.assoc_handle=amzn_dp_project_dee_de&openid.mode=checkid_setup&openid.claimed_id=http://specs.openid.net/auth/2.0/identifier_select&openid.ns=http://specs.openid.net/auth/2.0&
2019-09-24 10:50:23 DEBUG (MainThread) [alexapy.alexalogin] Found standard login page
2019-09-24 10:50:23 DEBUG (MainThread) [alexapy.alexalogin] Found post url to https://www.amazon.de/ap/signin
2019-09-24 10:50:23 DEBUG (MainThread) [alexapy.alexalogin] Preparing post to https://www.amazon.de/ap/signin Captcha: None SecurityCode: None Claimsoption: None AuthSelectOption: None VerificationCode: None
2019-09-24 10:50:24 DEBUG (MainThread) [alexapy.alexalogin] POST:
<CIMultiDictProxy('Host': 'www.amazon.de', 'User-Agent': 'Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/68.0.3440.106 Safari/537.36', 'Accept': 'text/html,application/xhtml+xml, application/xml;q=0.9,*/*;q=0.8', 'Accept-Language': '*', 'Referer': 'https://www.amazon.de/ap/signin?showRmrMe=1&openid.return_to=https://alexa.amazon.de/&openid.identity=http://specs.openid.net/auth/2.0/identifier_select&openid.assoc_handle=amzn_dp_project_dee_de&openid.mode=checkid_setup&openid.claimed_id=http://specs.openid.net/auth/2.0/identifier_select&openid.ns=http://specs.openid.net/auth/2.0&', 'Accept-Encoding': 'gzip, deflate', 'Cookie': 'session-id=259-0378558-4932951; session-id-time=2200035022l; session-token="Bc+yuSiMMeXt0viKO37PRYI+5JVQnTjQOV8V924WLiIKVZilTNcAY7/Ot2qAIWY9/wylx5wvpP4bj+oLu/5WNVAbLmd6IZWNkbtj/99R6Gx3VN/r4BkzmUsxpwKoOMB9p356uW9ayRzPemKmRmyllQ8822SdXrCbZwhtFN4u4P4z8hRNCs+wpzde2OUrZi3aFSWHQhxK3Hh4ufrQbhU/vwEBKsmPmxUOslj+wiSYmH4="; ubid-acbde=262-1885261-7052166', 'Content-Length': '749', 'Content-Type': 'application/x-www-form-urlencoded')>
2019-09-24 10:50:24 DEBUG (MainThread) [alexapy.alexalogin] Processing https://www.amazon.de/ap/signin
2019-09-24 10:50:24 DEBUG (MainThread) [alexapy.alexalogin] Error message: Wichtige Mitteilung!
2019-09-24 10:50:24 DEBUG (MainThread) [alexapy.alexalogin] Captcha requested
2019-09-24 10:50:24 DEBUG (MainThread) [alexapy.alexalogin] Found post url to https://www.amazon.de/ap/signin
2019-09-24 10:50:24 DEBUG (MainThread) [custom_components.alexa_media.config_flow] Testing login status: {'error_message': 'Wichtige Mitteilung!\n Zum besseren Schutz Ihres Kontos geben Sie bitte nochmals Ihr Passwort ein, und geben Sie dann die Zeichen ein, die in der Abbildung unten gezeigt werden.\n ', 'captcha_required': True, 'captcha_image_url': 'https://opfcaptcha-prod.s3.amazonaws.com/5d84f354069f4e8191d2f8c7b969f1a9.jpg?AWSAccessKeyId=AKIA5WBBRBBB3EQNKAH5&Expires=1569315324&Signature=PStIlrKD86kKCCc8L6HJjJ5G%2F1U%3D'}
2019-09-24 10:50:24 DEBUG (MainThread) [custom_components.alexa_media.config_flow] Creating config_flow to request captcha
2019-09-24 10:50:24 DEBUG (MainThread) [custom_components.alexa_media.config_flow] show_form captcha {'email': '[email protected]', 'url': 'amazon.de', 'captcha_image': '[](https://opfcaptcha-prod.s3.amazonaws.com/5d84f354069f4e8191d2f8c7b969f1a9.jpg?AWSAccessKeyId=AKIA5WBBRBBB3EQNKAH5&Expires=1569315324&Signature=PStIlrKD86kKCCc8L6HJjJ5G%2F1U%3D)', 'message': '\n> Wichtige Mitteilung!\n Zum besseren Schutz Ihres Kontos geben Sie bitte nochmals Ihr Passwort ein, und geben Sie dann die Zeichen ein, die in der Abbildung unten gezeigt werden.\n '} {} OrderedDict([('password', <class 'str'>), ('captcha', <class 'str'>)])
