Thanks alandtse,
I’m assuming that you mean the " either side of the url in the configuration.yaml file. I have removed them and this is now the error.
Log Details (ERROR)
Tue Aug 21 2018 19:32:09 GMT+1200 (New Zealand Standard Time)
Error while setting up platform alexa
File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 171, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw)
File "/usr/local/lib/python3.6/site-packages/urllib3/util/connection.py", line 56, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/local/lib/python3.6/socket.py", line 745, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -2] Name does not resolve
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 343, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 849, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 314, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 180, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x6fe2e9d0>: Failed to establish a new connection: [Errno -2] Name does not resolve
File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 445, in send
timeout=timeout
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/local/lib/python3.6/site-packages/urllib3/util/retry.py", line 398, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='alexa.alexa.amazon.com', port=443): Max retries exceeded with url: /api/devices-v2/device (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6fe2e9d0>: Failed to establish a new connection: [Errno -2] Name does not resolve',))
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 129, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File "/usr/local/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
return fut.result()
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/config/custom_components/media_player/alexa.py", line 115, in setup_platform
login = AlexaLogin(url, email, password, hass)
File "/config/custom_components/media_player/alexa.py", line 571, in __init__
self.login(cookies=cookies)
File "/config/custom_components/media_player/alexa.py", line 670, in login
resp = self._session.get(site)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 525, in get
return self.request('GET', url, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 512, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 622, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 513, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='alexa.alexa.amazon.com', port=443): Max retries exceeded with url: /api/devices-v2/device (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6fe2e9d0>: Failed to establish a new connection: [Errno -2] Name does not resolve',))
