I get this when trying to call the tts service, when I originally added the media player component and restarted I didn’t get the persistent card, but all the media players were in my front end.
http://192.168.1.81:8123/frontend_latest/app-c039924c.js:1213:26645 SecurityError: Blocked a frame with origin "http://192.168.1.81:8123" from accessing a cross-origin frame. Protocols, domains, and ports must match.
I’m wondering if this is related to ssl, as I don’t expose my instance outside my network as I have no need currently?
any pointers guys?
should probably add i’m running home assistant in a docker container on ubuntu server
I’m curious if the Gen 3 dots work in the US? I’d think so but want to verify. Today Amazon has a 3 pack of the Gen 3 Dots for $70. Not a bad price. Might replace some of my Gen 1 echos. But want to make sure they’ll work
I think the error was related to me calling the service from within an organizr window, opening homeassistant directly in the browser (safari) and calling the service results in no errors, unfortunately still no response from the echo, so clearly other issues elsewhere.
this is in the logs
ERROR (SyncWorker_6) [custom_components.media_player.alexa] An error occured accessing the API: An exception of type JSONDecodeError occurred. Arguments: ('Expecting value: line 1 column 1 (char 0)',)
not sure if its an error in the Alexa.py file (downloaded from GitHub and pasted the media_player folder into the custom components folder) or something else?
seems to that or something went wrong with your first login or with any of your devicenames.
could it be that you got strange characters in it? (or password or mail)
and with strange i mean like ü or é or something simular?
i also dont know if gen 3 gives up new problems in germany.
but with the prices from this moment i am willing to try.
allthough overhere they are no where near as cheap. 30 euro for 1 (about 35 dollar)
still i bought 5 gen 3 (and to make sure it will work also 2 gen 2, because they are only 25 euro )
I’m having difficulty interacting with my alexa devices. I can SEE them and they update with what’s being played etc, but changing volume, trying to use tts and pressing pause/play does absolutely nothing (apart from at the bottom it says service called).
but you can create a skill and start that skill with the tts service. something we cant do.
and the skill can speak the response.
After reading this I made a (private) skill to replicate Simon says but unfortunately it doesn’t work. I mean, the skill itself works flawlessly (I use it to ask stats and other infos to HA instance) but trying to make Alexa speaking custom text is not working.
If I send “chiedi a Tom ripeti messaggio testo da ripetere” (in english: “tell Tom repeat message text to repeat”) to media player it returns error message sound (If I try same message from aws testing skills page it works)…so I think we have to wait something from Amazon to have a TTS in Italian
is it the skill that errors out or the TTS service?
I think is something related to API call. If I say that message to Alexa it works so skill is not the problem and TTS service works as expected because if I send (from services in HA panel) something that can be treated as a command like “notizie” (“news” in english) Alexa starts speaking with the today news or if I send “meteo” (“weather” in english) Alexa starts weather news so TTS works too.
what do you see in the alexa history?
Well…nothing…I mean, in Alexa history I see only working command (like “meteo” or “notizie”) but no history entry of my skill calls from TTS service.
I tried same commands with this script with same results.
