Connection refused on port 22222
Have tried to follow https://home-assistant.io/developers/hassio/debugging/ but no luck so far
Thx all, this worked like a charm!
SInce Version 107.x the source files in the docker container are located at /usr/src/homeassistant
Second this. Thanks to all of you.
Just remember, if you copy the integration from core to custom_components, you have to add a dummy version in the manifast file. Otherwise it is not loaded anymore, due to recent changes in core.
How it‘s possible to make changes in the manifest? I’m searching for hours now :-/
You can take more or less any text editor of your choice.
