How can I do that ? Before 2021.9 I Was using a custom component that was working very well but after the upgrade the sensor was seen as unknown…
Now I moved away the Custom Component and the sensor says me that it state_class is not the one expecet ( not measuremet anymore but “total Increasing” …
Unexpected state class
The following entities do not have the expected state class 'total_increasing'
sensor.energy_consumed
I got the solution for my problem explained in the previous post…
What i did to solve after the upgrade:
1 delete the custom integration efergy
2 in configuration.yaml set the customize_glob with state total_increasing for my efergy sensor (only for it )
3 wait for the data update…
Customize_glob:
sensor.energy_consumed:
unit_of_measurement: "kWh"
device_class: energy
state_class: total_increasing
last_reset: "1970-01-01T00:00:00+00:00"
i Am new to this and have the efergy monitor . my readings are still off and have followed most of what’s been completed above to get it to work, would it be possible for you to share the custom PR settings
well, i consciously waited for today’s update before fiddling around to get efergy integrated in the energy monitoring. so i just updated, but still i can’t select it as a statistic for grid consumption
might removing and re-adding the integration change anything?
I don’t think it made it into the release. I saw mention of it in the RC notes, but there was no mention in the final release - and just like yourself, mine still isn’t working after updating.
OK. So with the latest update, Efergy was pulled into the integration page and now the total consumption now shows up as a value that can be pulled into the energy tab.
Any ideas on how to bring all your additional CT’s clamps which are connected to the efergy hub into HA? I can see their wattage but it does not automatically generate a kWh value.
Are you sure it shows one of the clamps or does it show the total energy consumption?
Also, I had quite a few entities in the Efergy integration disabled. Maybe your missing clamps are there?
Its a mess. My AC on the efergy works just mostly fine using Riemann sum integral. My geyser using the exact same integration is completely out (recording more than double the usage of who whole house)
