@Vennerberg thanks for the remark. tried that but without succes.
Config file error:
Invalid config for [http]: not a file for dictionary value @ data['http']['ssl_certificate']. Got 'fullchain.pem'
not a file for dictionary value @ data['http']['ssl_key']. Got 'privkey.pem'. (See /config/configuration.yaml, line 44). Please check the docs at https://home-assistant.io/components/http/
Wait hold on… in configuration.yaml it’s supposed to be as you stated. With https:// and /ssl/ In the hassio config for duckdns it’s supposed to be as I said. No https, no ports and no /ssl/
And my config file is
this is in my configurations file:
http:
base_url: https://secret.duckdns.org:8123
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
@DavidFW1960
Because the DuckDNS ad-on now support the LetsIncrypt. And as it uses that “ad-on” / addition also, my reasoning was to also open that port.
Thanks, will try this tonight, from the office is it bit tricky to forward ports at home and restarting plugins. Will let you know what the result was.
With the duckdns addon it uses the DNS validation instead of HTTP - that is why it doesn’t require port 80.
Regarding other forwards… if you forward port 8123 to 8123 then you always need to specify the :8123 at the end of the HA URL. If you forward 443 to 8123 then you don’t need to specify any port.
if i do what you ask in the configuration.yaml file i get the following:
Configuration invalid
not a file for dictionary value @ data['http']['ssl_key']. Got 'privkey.pem'. (See /config/configuration.yaml, line 23). Please check the docs at https://home-assistant.io/components/http/
