Perhaps the way to expose the functionality of a Task firing is to just generate a custom event on the event bus. The Z-Wave component generates “scene activated” events when I push a button on a Z-Wave remote.
Yeah, we might have to change it if we can’t find a way for automations to trigger on the scene activating. Thus far I haven’t found a clean way of doing it, but most of my Google results are for triggering scene from an automation, not the other way around.
Just looked for the state change event as a trigger to kick off an automation. I seems to have these left-over in my configuration…
# watch for Elk automation invocation events for turning outside lights on and off
- alias: elk Ext Lights On
initial_state: True
platform: state
entity_id: switch.elk_task_009
to: "on"
- service: homeassistant.turn_on
entity_id: group.outside_lights
- service: logbook.log
data_template:
name: Elk Outside Lights On Task On
message: "Elk Outside Lights task ON at {{ now().strftime('%Y-%m-%d %H:%M:%S') }}"
# replicate behavior of Elk task that turns off lights after
# 15 minutes
- alias: elk Ext Lights On - After Timeout
initial_state: True
platform: state
to: "off"
for:
minutes: 15
- service: homeassistant.turn_off
data_template:
name: Elk Outside Lights On Task timeout
message: "Elk Outside Lights task ON timeout at {{ now().strftime('%Y-%m-%d %H:%M:%S') }}"
- alias: elk Ext Lights Off
initial_state: True
platform: state
entity_id: switch.elk_task_010
to: "on"
data_template:
name: Elk Outside Lights Off Task
In these examples, the Elk tasks got kicked off due to a keypad interaction.
I’m not sure if these still work any longer. When I looked earlier at the event stream coming out of Home Assistant, all I see is the associated switch changing state to “off”. Some probably has changed somewhere along the way and I didn’t notice. Lately, these automations really are not needed for me since I look for my Z-Wave door lock being unlocked to automagically deal with the outside lights…
Just having some custom event fired would “work” for me. I think there might be other opportunities to use Elk-specific events to notify when other random things happen? Maybe programming mode start/end, etc.
I asked about this on the HASS Discord and was told :
there should be an event fired by home assistant when the service is executed and the scene entity is activated. So we should be able to make an automation that triggers on the corresponding event message. Event name should be service_executed and then match on the event data. Automation Trigger - Home Assistant
So that may be another solution. Just have to figure out the right event_data combination, etc.
Thanks to the ceaseless efforts of @gwww we will hopefully be in HASS 0.81. There will be breaking changes, especially for anyone on the older versions… but functionally you should lose nothing, just have to reformat or rename various things, etc…
Thanks to @BioSehnsucht and @gwww for the tireless efforts getting this amazing work merged into the Home Assistant code base. I was stalking the various pull requests on github, and it was a herculean effort to tweak and tune and modify the (already working quite nicely!) code to match the stylistic guidelines for Home Assistant. Especially when some of those guidelines were unknowable ahead of time.
Thank you @BioSehnsucht! You got us all going on this journey. Your insight and understanding of the ElkM1 was instrumental.
To all those who have tested and helped us get to a quality integration, thank you!
If you have a thermostat, please do some extra testing. All I can say is that the code appears to work. I did as mush testing as I could without an actual thermostat.
Yes, there are a lot of changes with the integration into HASS. Some I wish didn’t have to be made. However in the end I think we will end up with a better system, even if there is some short term pain. Fire your questions to the list when you stumble across something not working. Better still take a peek at the code. There’s an attempt to make the code readable. But, yah it is still code.
Integrations have Lovelace in mind. So, for example, there’s no hidden in the Elk config any more. I encourage you all to start to play with Lovelace. Take a look at the work by Marius for some custom Lovelace components https://github.com/ciotlosm/custom-lovelace. I have contributed heavily to the alarm_control_card (for arming/disarming). It too needs a bit of work to deal with “custom” arming modes such as arm_vacation.
HASS continues to evolve. I expect that the Elk-M1 integration will also have to evolve. Time to take a break for bit before looking at any evolution.
On to my next projects … I’m looking at better UPB lighting integration (the Elk integration already supports it, but the Elk-M1 is missing stuff). And probably will start to tune up the alarm_control_card.
I am running into an issue with elk module after upgrading to 0.81
I have reduce my config to a simple:
elkm1:
host: elk://
However I get this error:
Invalid config for [elkm1]: invalid temperature unit (expected C or F) for dictionary value @ data[‘elkm1’][‘temperature_unit’]. Got None. (See /home/homeassistant/.homeassistant/configuration.yaml, line 78). Please check the docs at https://home-assistant.io/components/elkm1/
8:00 PM config.py (ERROR)
If I add config for temperature_unit the error repeats for the next missing “optional” config item. It is as if none of the optional config items are optional.
So now that the integration into HASS is complete, do we just delete the custom components that we created before so that it operates off the (newly) native integration?
