Are you talking about using the FGW14WL-IP, @netzgauner ?
No, it’s the Eltako FGW14-USB RS485 Gateway.
I think the IP version is like some posts up for an
electricity meter.
This is what i have and works:
https://www.voelkner.de/products/6442828/Eltako-FGW14-USB-RS485-Gateway-Rack.html
And with an active usb cable connected.
Yeah, I have that too. I just didn’t get the link to MQTT. I thought you are using the IP gateway as they mention MQTT in their data sheet (for energy meters).
Do you expose the bus telegrams/messages to MQTT? Just asking as I’mm trying to understand your post
You mean because of the cross checked via mqtt. That was via radio without the FGW14. Only by FAM14.
Hello @philipp14
I think I fixed the problem with the value state in the intermediate position.
Thats what I have changed.
I have tested it and now only when the cover ist closed, the status closed is shown. Otherwise, opening, closeing, or open, is displayed.
I stumbled upon this thread and was very happy that at last there is an integration for the eltako bus system. I am using node red for controlling my eltako devices for now and I would like to switch over.
I have installed the integration and added a FUD14 and FSR14 to my config.yaml file. I can control both of them but it seems that there is no feedback from the state of the light.
Currently I’m using my FAM14 with BA on 4 and Auto on 1.
So in the image above I can turn on the light with the switch on the right but it turns back of after 1 second. The light wil stay on and I can switch it off and back on if I click on the lightbulb and use the switch there. This is with the FSR14. With the FUD14 the behavior of the switch on the right is the same. If I click on the lightbulb I can change the brightness of the light but not switch it off.
Is this because I use the FAM14 and not the FGW14 or am I missing something somewhere ?
I think you need a fgw14. As far as I know, the usb port of the fam14 is only for configuration with pct software.
I bought one but the problem is still the same. Any other thoughts what might cause this ?
Does the confirmation telegram of the FSR14 show up in your logs?
Hi legnad,
I checked the logs and the confirmation is send as shown below. This is when I use the switch within HA. It seems that HA does not change the state as the switch slider turns back off after a second or 2.
Could it be that there is something wrong with my conf.yaml ?
2023-08-25 17:22:07.406 DEBUG (SyncWorker_8) [eltako] Send message: <Regular4BSMessage from ff d4 ed 90, data 01 00 00 09, status = 0x00> - Serialized: a55a6b0701000009ffd4ed9000cc
2023-08-25 17:22:08.556 DEBUG (MainThread) [eltako] Received message: <ESP2Message '8b 05 70 00 00 00 00 00 00 09 30'>
2023-08-25 17:22:08.604 DEBUG (MainThread) [eltako] Received message: <ESP2Message '8b 05 70 00 00 00 00 00 00 0a 30'>
2023-08-25 17:22:09.991 DEBUG (SyncWorker_4) [eltako] Send message: <Regular4BSMessage from ff d4 ed 90, data 01 00 00 08, status = 0x00> - Serialized: a55a6b0701000008ffd4ed9000cb
2023-08-25 17:22:11.340 DEBUG (MainThread) [eltako] Received message: <ESP2Message '8b 05 50 00 00 00 00 00 00 09 30'>
2023-08-25 17:22:11.404 DEBUG (MainThread) [eltako] Received message: <ESP2Message '8b 05 50 00 00 00 00 00 00 0a 30'>
Hi Vinnovic,
Could you write the entries in the configuration.yaml from one of your FSR14?
This is the entry for the FSR14
eltako:
light:
- id: "FF-A7-2E-89"
eep: "M5-38-08"
sender:
eep: "A5-38-08"
According to the PCT14 software, is “FF-D4-ED-90” programmed in the actuator as a channel with source GFVS or controller and function 51?
It is programmed as controller and function 51. The GFVS option is not available for the FSR
I found it. It seemed that I was using the wrong adress for the acuators
I have a Eltako setup running for al lot of years (using FHEM) but are switching to HA.
The FUD dimmers work fine when I use the Enocean-intergration but the FSR relays don’t.
I do use FSR12 but what I have found these should work with the same telegrams only there is no status feedback. So what I would like to test is to switch the left and right relay in one FSR12-12VDC.
The baseID for the USB300 is FF-8C-E8-80 and the relay is FF-8C-E8-82.
I tried various config’s but cannot get the USB300 to send an on or off signal to the relay.
Can somebody help me to setup the config?
Hallo @heubie,
I’m currently working on the hearing and cooling parts of the eltako integration.
I can try to make it compatible to 12-series but don’t have any device to test with.
By quickly looking at it, it should be already compatible to fsr14. For sending I use EEP a5-38-08 (gateway command) Could you please find out what EEP command are used by fsr14 and you could also send me the log lines from actor responses.
Have you entered a sensor into the eltako device which is also registered in the config like here: https://github.com/grimmpp/home-assistant-eltako/blob/d5d95b2738d275d69d62fb4c81627755160cde82/ha.yaml#L6
And you should use eep a5-38-08 for the light actor instead of m5-38-08. Both are supported in parallel.
Hope this helps.
I would love to do the testing but as for now I don’t get the gateway to send anything. When I use FHEM and send a switch command both leds on the receiver and the connected FSR12 blink. The same counts for switching a light when using Enocean in HA. But I cannot get the USB300 to send anything.I need a basic config file with my baseID for the USB300 being FF-8C-E8-80 and a receiving relay on adress FF-8C-E8-82 so that I can test when I flip the switch in HA at least the led’s blink. From there I will use my rs485-converter and and a laptop to see what is send and if it works. But I need it to send “something” in the first place.
I hope this makes sens.
Regs
Hello dear friends of Eltako!
I just found this implementation and made it work (at least up to the detection of my binary sensors).
Now I have 2 things I need help with.
- F4HK14 (4x Floor-Heating Module)
At the moment it is not implemented. To feed it with data, I expect you would need to simulate a temperature sensor which is also not yet implemented.
Luckily I have everything set up for testing (I got a FTR65, which provides Real-Temp, Set-Temp and a Night-Switch) and is accepted by th F4HK14. Unfortunately I have no idea where to start to get that running and implemented, but I can test & debug as needed.
FTR65
EEP: A5-10-06
Byte 2 SET POINT (Linear 0...255) - 0x76 = 18,5°C, Stepping: 0,16°C
Byte 3 TEMP 255...0 (0 bis +40°C) - 0x85 = 19,15°C
- I have FSA12 and FSB12 behind a FGW14 (low priority). How do I address those? I know how addressing on BR14 works, but the BR12 do not fit in that scheme (do they have any address at all?).
If they don’t have their address… how do I simulate just a press of a binary sensor?
