What is not working, is there an error message. If the forecast is not accurate can you show some plots?
Change the PV module to something closer to your module peak power (360W). For example Phono_Solar_Technology_Co__Ltd__PS360MH_24_T. For the inverter the Fronius 5kW should be ok.
On each of your inverters you have panels with different tilt/azimuth?
Depending on your answer you should modify accordingly but your configuration for two inverters should look like this:
2023-01-20 09:31:58,228] ERROR in app: Exception on /action/perfect-optim [POST]
File "/usr/local/lib/python3.9/dist-packages/requests/models.py", line 971, in json
return complexjson.loads(self.text, **kwargs)
File "/usr/lib/python3.9/json/__init__.py", line 346, in loads
return _default_decoder.decode(s)
File "/usr/lib/python3.9/json/decoder.py", line 340, in decode
raise JSONDecodeError("Extra data", s, end)
json.decoder.JSONDecodeError: Extra data: line 1 column 4 (char 3)
File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 2525, in wsgi_app
response = self.full_dispatch_request()
File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 1822, in full_dispatch_request
rv = self.handle_user_exception(e)
File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 1820, in full_dispatch_request
rv = self.dispatch_request()
File "/usr/local/lib/python3.9/dist-packages/flask/app.py", line 1796, in dispatch_request
return self.ensure_sync(self.view_functions[rule.endpoint])(**view_args)
File "/usr/local/lib/python3.9/dist-packages/emhass/web_server.py", line 134, in action_call
input_data_dict = set_input_data_dict(config_path, str(config_path.parent), costfun,
File "/usr/local/lib/python3.9/dist-packages/emhass/command_line.py", line 66, in set_input_data_dict
rh.get_data(days_list, var_list,
File "/usr/local/lib/python3.9/dist-packages/emhass/retrieve_hass.py", line 121, in get_data
data = response.json()[0]
File "/usr/local/lib/python3.9/dist-packages/requests/models.py", line 975, in json
raise RequestsJSONDecodeError(e.msg, e.doc, e.pos)
Please show your configuration and the shell command that you’re using.
You’re trying to do what is called in EMHASS as “perfect optimization”, this is an optimization based on past historical and known values. If those historical values are not saved by the Home Assistant recorder then you will have this kind of issues.
The “Day-ahead optimization” is working?
Hard to say. we will wait to 23:57 again to see. since emhass cannot be restarted and published in the middle of the day since we are not parsing time and date we are only able to test this 23:57
You should be able to launch forecasts whenever you want. I understand that nordpool forecast are updated just one time a day but you should be able to manage that data and concatenate a list of values with the correct length expected by EMHASS.
You should be able to do that with templates and then trigger an optimization whenever you want.
Of course, because you’re only using “tomorrow” values. So if you run it at 23:57 everything is ok. But if you want to run it in the middle of the day then you should concatenate “today” + “tomorrow” values.
edit, tested and woring. Including today and tomrow prices. removes expired prices and limit to 24. Worked for me mabey someone else also like to use it.
Ok, so you wrote about the azimuth, are sure about thosz values. Double check tilt and azimuth parameters. You should have two different set of values for each of those parameters.
A third method uses the Solar.Forecast service. You will need to set method=solar.forecast and use just one parameter solar_forecast_kwp (the PV peak installed power in kW) that should be passed at runtime.
I need som help to setup up the Solar.Forecast service. I get errors in the Emhass log when I do a Day-Ahead optimization. I am using this shell command:
File "/usr/local/lib/python3.9/dist-packages/emhass/web_server.py", line 135, in action_call
input_data_dict = set_input_data_dict(config_path, str(data_path), costfun,
File "/usr/local/lib/python3.9/dist-packages/emhass/command_line.py", line 81, in set_input_data_dict
df_weather = fcst.get_weather_forecast(method=optim_conf['weather_forecast_method'])
File "/usr/local/lib/python3.9/dist-packages/emhass/forecast.py", line 248, in get_weather_forecast
"/"+str(self.plant_conf["surface_tilt"])+"/"+str(self.plant_conf["surface_azimuth"]-180)+\
TypeError: unsupported operand type(s) for -: 'list' and 'int'
[2023-02-06 20:13:46,801] INFO in command_line: Setting up needed data
[2023-02-06 20:13:46,804] ERROR in utils: ERROR: The passed data is either not a list or the length is not correct, length should be 24
[2023-02-06 20:13:46,805] ERROR in utils: Passed type is <class 'list'> and length is 24
[2023-02-06 20:13:46,806] ERROR in utils: ERROR: The passed data is either not a list or the length is not correct, length should be 24
[2023-02-06 20:13:46,806] ERROR in utils: Passed type is <class 'list'> and length is 24
[2023-02-06 20:13:46,812] INFO in forecast: Retrieving weather forecast data using method = solar.forecast
[2023-02-06 20:13:46,813] ERROR in app: Exception on /action/dayahead-optim [POST]
The config for the solar panels, microinverter, azimuth, angle are publish here:
