EMHASS: An Energy Management for Home Assistant
I’m using the shell commands listed below and calling them with node-red (also below). I plan to convert the shell commands in config.yaml to node-red when I understand them better. I prefer the visual nature of node-red.
But I’m only calling:
  1. dayahead_optim at 05:30.
  2. post_mpc_optim_solcast and publish_data every 5 min.
I’m not calling post_amber_forecast or post_emhass_forecast at all. This must be the issue? How often are these two shell commands meant to be called?
shell_command:
  dayahead_optim: 'curl -i -H "Content-Type: application/json" -X POST -d ''{}'' http://localhost:5000/action/dayahead-optim'
  publish_data: 'curl -i -H "Content-Type: application/json" -X POST -d ''{}'' http://localhost:5000/action/publish-data'
  post_amber_forecast:
    'curl -i -H ''Content-Type: application/json'' -X POST -d ''{"prod_price_forecast":{{(
    state_attr(''sensor.cecil_st_feed_in_forecast'', ''forecasts'')|map(attribute=''per_kwh'')|list)
    }},"load_cost_forecast":{{(
    state_attr(''sensor.cecil_st_general_forecast'', ''forecasts'') |map(attribute=''per_kwh'')|list)
    }},"prediction_horizon":33}'' http://localhost:5000/action/dayahead-optim'
  post_emhass_forecast:
    }},{{states(''sensor.solcast_24hrs_forecast'')}},"load_cost_forecast":{{(
    }}}'' http://localhost:5000/action/dayahead-optim'
  post_mpc_optim_solcast:
    'curl -i -H "Content-Type: application/json" -X POST -d ''{"load_cost_forecast":{{(
    ([states(''sensor.cecil_st_general_price'')|float(0)] +
    state_attr(''sensor.cecil_st_general_forecast'', ''forecasts'') |map(attribute=''per_kwh'')|list)[:48])
    }}, "prod_price_forecast":{{(
    ([states(''sensor.cecil_st_feed_in_price'')|float(0)] +
    state_attr(''sensor.cecil_st_feed_in_forecast'', ''forecasts'')|map(attribute=''per_kwh'')|list)[:48])
    }}, "pv_power_forecast":{{states(''sensor.solcast_24hrs_forecast'')
    }}, "prediction_horizon":48,"soc_init":{{(states(''sensor.sonnenbatterie_84324_state_charge_user'')|float(0))/100
    }},"soc_final":1.0,"def_total_hours":[2,2,2,0]}'' http://localhost:5000/action/naive-mpc-optim'
# def_total_hours [Deferrable_0=PoolPump] [Deferrable_1=DW] [Deferrable_2=WM&D] [Deferrable_3=tesla]
Node-red flows:
They are set up like this one:
Again thanks
