The thing about pulling it off completely can be tricky as it requires a lot of energy to get up to the target temperature.
Ideally, I would like to have a set point of 21 degrees C and then that at expensive it lowers a degree and vice versa at cheap.
What controls do you have available? On/off or setpoint?
Itβs a zigbee thermostat so I have several ways to control it
Do you have specific times you want the floor heated?
At night, it can lower, but not too much, as I mentioned before that it may require some energy to get warm again.
I have tried to read about thermal mode but think it looks very complicated, and have a bit of a hard time seeing how to implement it in my rest command.
