Hi thanks for the feedback!
Version 0.1.16 loaded correctly on my odroid n2+, which is the same hardware as HA Blue so that is a start.
You will need to rebuild as I have just updated EMHASS (the module not the add-on)
I am not currently on my local network, and access HA via Nabu Casa, so I presume I cannot access EMHASS, which makes control difficult outside of LAN. Interesting other Add-Onās can still access localhost, so there maybe a way around that I havenāt identifed.
Ok so in version 0.1.16 (the latest) Iām using directly communication with the supervisor. So EMHASS should be able to communicate directly with your hass core instance. Have you tested the connection?
I have multiple inverters with multiple strings pointing in different directions, which doesnāt seem to be supported in the EMHASS configuration setup. I am also interested in the use of pvlib within EMHASS given the HA energy dashboard already has good support for solar forecasting though either the Solcast or Forecast.Solar integrations, which in my case are already setup.
Ok this is a very nice use case, I will definitely update the code in the near future to support multiple inverters. The core code is actually ready for this as everything is in lists, so you we could have a list of inverters with no problem. But I will need to work a little bit further on the add-on.
For you to use PVLib inside EMHASS you will have to provide and pass the irradiance and temperature forecasts provided by whatever service you want. As you said this is already implemented in HA, so it will be nice to retrieve these forecasts directly. This is already possible using your own CSV files with my EMHASS Python module but not the Add-on. I will also update the add-on for you to be able to import directly the variables from those forecasting services you mentioned. I will work on it.
EMHASS assumes that the solar compensation, TOU pricing and timings are constant, but there are other cases. I have forecast and actual feed in and general tariff pricing available in 30 minute blocks vi the Amber Electric Integration. That is OK, I can make a steady state approximation as to my TOU windows and pricing, but something to consider for the future, and something that would really benefit from the LP, although I suspect the calculations may need to occur more than once a day as my forecast pricing is updated every 30 minutes.
Again this is actually already implemented in the EMHASS Python module but still not in the add-on. I was trying to figure out how to possible import variable pricings. The Amber Electric integration is just for AU users, so I will need to find a more generalized solution. How to feed a forecast variable to EMHASS?
EMHASS assumes that the deferable loads needs to run for a fixed number of hours but there are other cases. My EV/ Home Battery charging time is an inverse function with its state of charge, the Power draw for EV charging can also be modulated to self consume excess solar, my Pool Heating time is a function of the temperature difference with the desired set point. My HVAC running time is a bizzare function of the temperature difference with the desired set point with an allowance for pre heating/ cooling before electricity price peak windows.
There are definitely a lot of using cases to take care of. For now an answer to the EV case. You can consider adding a battery to EMHASS and fix a discharging power to zero and a target SOC to whatever SOC you want the EV to be at the end of the day.
