I’m only running the following shell commands:
- post_amber_forecast at 5:30am
- post_mpc_optim_solcast - every 60 second
- publish_data - every 60 second
shell_command:
dayahead_optim: 'curl -i -H "Content-Type: application/json" -X POST -d ''{}'' http://localhost:5000/action/dayahead-optim'
publish_data: 'curl -i -H "Content-Type: application/json" -X POST -d ''{}'' http://localhost:5000/action/publish-data'
post_amber_forecast:
'curl -i -H ''Content-Type: application/json'' -X POST -d ''{"prod_price_forecast":{{(
state_attr(''sensor.cecil_st_feed_in_forecast'', ''forecasts'')|map(attribute=''per_kwh'')|list)
}},"load_cost_forecast":{{(
state_attr(''sensor.cecil_st_general_forecast'', ''forecasts'') |map(attribute=''per_kwh'')|list)
}},"prediction_horizon":33}'' http://localhost:5000/action/dayahead-optim'
post_emhass_forecast:
}},{{states(''sensor.solcast_24hrs_forecast'')}},"load_cost_forecast":{{(
}}}'' http://localhost:5000/action/dayahead-optim'
post_mpc_optim_solcast:
'curl -i -H "Content-Type: application/json" -X POST -d ''{"load_cost_forecast":{{(
([states(''sensor.cecil_st_general_price'')|float(0)] +
state_attr(''sensor.cecil_st_general_forecast'', ''forecasts'') |map(attribute=''per_kwh'')|list)[:48])
}}, "prod_price_forecast":{{(
([states(''sensor.cecil_st_feed_in_price'')|float(0)] +
state_attr(''sensor.cecil_st_feed_in_forecast'', ''forecasts'')|map(attribute=''per_kwh'')|list)[:48])
}}, "pv_power_forecast":{{states(''sensor.solcast_24hrs_forecast'')
}}, "prediction_horizon":48,"soc_init":{{(states(''sensor.sonnenbatterie_84324_state_charge_user_decimal'')|float(0))/100
}},"soc_final":1.0,"def_total_hours":[2,2,2,2]}'' http://localhost:5000/action/naive-mpc-optim'
# def_total_hours [Deferrable_0=PoolPump] [Deferrable_1=DW] [Deferrable_2=WM&D] [Deferrable_3=tesla]
Only deferrable0 (pool pump) is actually being automated. The other 3 are possibly not suitable (dishwasher, Washing machine and dryer and car charger) as they are used randomly. May remove them as deferrables.
PV forecast
- platform: rest
name: "Solcast Forecast Data"
json_attributes:
- forecasts
resource: https://api.solcast.com.au/rooftop_sites/XXXX-XXXX-XXXX-XXXX/forecasts?format=json&api_key=XXXXXXXXXXXXXXXXXXXXXXXXXXXXX&hours=24
method: GET
value_template: "{{ (value_json.forecasts[0].pv_estimate)|round(2) }}"
unit_of_measurement: "kW"
device_class: power
scan_interval: 00:30
force_update: true
Getting some errors in logs:
2023-07-10 17:35:03,254 - web_server - INFO - Performing naive MPC optimization
2023-07-10 17:35:03,268 - web_server - INFO - Perform an iteration of a naive MPC controller
2023-07-10 17:35:03,381 - web_server - INFO - Status: Infeasible
2023-07-10 17:35:03,382 - web_server - INFO - Total value of the Cost function = -3.63
2023-07-10 17:35:03,796 - web_server - INFO - Setting up needed data
2023-07-10 17:35:03,799 - web_server - INFO - >> Publishing data...
2023-07-10 17:35:03,799 - web_server - INFO - Publishing data to HASS instance
2023-07-10 17:35:03,816 - web_server - INFO - Successfully posted to sensor.p_pv_forecast = -0.75
2023-07-10 17:35:03,828 - web_server - INFO - Successfully posted to sensor.p_load_forecast = 994.22
2023-07-10 17:35:03,839 - web_server - INFO - Successfully posted to sensor.p_deferrable0 = 0.0
2023-07-10 17:35:03,850 - web_server - INFO - Successfully posted to sensor.p_deferrable1 = 0.0
2023-07-10 17:35:03,861 - web_server - INFO - Successfully posted to sensor.p_deferrable2 = 0.0
2023-07-10 17:35:03,877 - web_server - INFO - Successfully posted to sensor.p_deferrable3 = 0.0
2023-07-10 17:35:03,890 - web_server - INFO - Successfully posted to sensor.p_batt_forecast = -1945.26
2023-07-10 17:35:03,899 - web_server - INFO - Successfully posted to sensor.soc_batt_forecast = 10.0
2023-07-10 17:35:03,909 - web_server - INFO - Successfully posted to sensor.p_grid_forecast = 2940.24
2023-07-10 17:35:03,918 - web_server - INFO - Successfully posted to sensor.total_cost_fun_value = -3.63
2023-07-10 17:35:03,931 - web_server - INFO - Successfully posted to sensor.unit_load_cost = 0.52
2023-07-10 17:35:03,942 - web_server - INFO - Successfully posted to sensor.unit_prod_price = 0.42
2023-07-10 17:36:00,051 - web_server - INFO - Setting up needed data
2023-07-10 17:36:00,053 - web_server - ERROR - ERROR: The passed data is either not a list or the length is not correct, length should be 48
2023-07-10 17:36:00,053 - web_server - ERROR - Passed type is <class 'list'> and length is 48
2023-07-10 17:36:00,056 - web_server - INFO - Retrieve hass get data method initiated...
2023-07-10 17:36:00,691 - web_server - INFO - Retrieving weather forecast data using method = scrapper
2023-07-10 17:36:02,463 - web_server - INFO - Retrieving data from hass for load forecast using method = naive
2023-07-10 17:36:02,464 - web_server - INFO - Retrieve hass get data method initiated...
2023-07-10 17:36:03,907 - web_server - INFO - >> Performing naive MPC optimization...
2023-07-10 17:36:03,908 - web_server - INFO - Performing naive MPC optimization
2023-07-10 17:36:03,917 - web_server - INFO - Perform an iteration of a naive MPC controller
2023-07-10 17:36:04,016 - web_server - INFO - Status: Infeasible
2023-07-10 17:36:04,017 - web_server - INFO - Total value of the Cost function = -3.61
2023-07-10 17:36:04,356 - web_server - INFO - Setting up needed data
2023-07-10 17:36:04,359 - web_server - INFO - >> Publishing data...
2023-07-10 17:36:04,359 - web_server - INFO - Publishing data to HASS instance
2023-07-10 17:36:04,374 - web_server - INFO - Successfully posted to sensor.p_pv_forecast = -0.75
2023-07-10 17:36:04,387 - web_server - INFO - Successfully posted to sensor.p_load_forecast = 996.8
2023-07-10 17:36:04,398 - web_server - INFO - Successfully posted to sensor.p_deferrable0 = 0.0
2023-07-10 17:36:04,410 - web_server - INFO - Successfully posted to sensor.p_deferrable1 = 0.0
2023-07-10 17:36:04,421 - web_server - INFO - Successfully posted to sensor.p_deferrable2 = 0.0
2023-07-10 17:36:04,433 - web_server - INFO - Successfully posted to sensor.p_deferrable3 = 0.0
2023-07-10 17:36:04,445 - web_server - INFO - Successfully posted to sensor.p_batt_forecast = -1947.37
2023-07-10 17:36:04,458 - web_server - INFO - Successfully posted to sensor.soc_batt_forecast = 10.0
2023-07-10 17:36:04,473 - web_server - INFO - Successfully posted to sensor.p_grid_forecast = 2944.92
2023-07-10 17:36:04,486 - web_server - INFO - Successfully posted to sensor.total_cost_fun_value = -3.61
2023-07-10 17:36:04,502 - web_server - INFO - Successfully posted to sensor.unit_load_cost = 0.52
2023-07-10 17:36:04,517 - web_server - INFO - Successfully posted to sensor.unit_prod_price = 0.42
2023-07-10 17:37:00,032 - web_server - INFO - Setting up needed data
2023-07-10 17:37:00,033 - web_server - ERROR - ERROR: The passed data is either not a list or the length is not correct, length should be 48
2023-07-10 17:37:00,033 - web_server - ERROR - Passed type is <class 'list'> and length is 48
2023-07-10 17:37:00,035 - web_server - INFO - Retrieve hass get data method initiated...
2023-07-10 17:37:00,591 - web_server - INFO - Retrieving weather forecast data using method = scrapper
2023-07-10 17:37:02,428 - web_server - INFO - Retrieving data from hass for load forecast using method = naive
2023-07-10 17:37:02,428 - web_server - INFO - Retrieve hass get data method initiated...
2023-07-10 17:37:03,474 - web_server - INFO - >> Performing naive MPC optimization...
2023-07-10 17:37:03,474 - web_server - INFO - Performing naive MPC optimization
2023-07-10 17:37:03,486 - web_server - INFO - Perform an iteration of a naive MPC controller
2023-07-10 17:37:03,638 - web_server - INFO - Status: Infeasible
2023-07-10 17:37:03,639 - web_server - INFO - Total value of the Cost function = -3.6
2023-07-10 17:37:04,056 - web_server - INFO - Setting up needed data
2023-07-10 17:37:04,058 - web_server - INFO - >> Publishing data...
2023-07-10 17:37:04,058 - web_server - INFO - Publishing data to HASS instance
2023-07-10 17:37:04,081 - web_server - INFO - Successfully posted to sensor.p_pv_forecast = -0.75
2023-07-10 17:37:04,097 - web_server - INFO - Successfully posted to sensor.p_load_forecast = 984.64
2023-07-10 17:37:04,108 - web_server - INFO - Successfully posted to sensor.p_deferrable0 = 0.0
2023-07-10 17:37:04,119 - web_server - INFO - Successfully posted to sensor.p_deferrable1 = 0.0
2023-07-10 17:37:04,132 - web_server - INFO - Successfully posted to sensor.p_deferrable2 = 0.0
2023-07-10 17:37:04,144 - web_server - INFO - Successfully posted to sensor.p_deferrable3 = 0.0
2023-07-10 17:37:04,160 - web_server - INFO - Successfully posted to sensor.p_batt_forecast = -1949.47
2023-07-10 17:37:04,173 - web_server - INFO - Successfully posted to sensor.soc_batt_forecast = 10.0
2023-07-10 17:37:04,186 - web_server - INFO - Successfully posted to sensor.p_grid_forecast = 2934.87
2023-07-10 17:37:04,195 - web_server - INFO - Successfully posted to sensor.total_cost_fun_value = -3.6
2023-07-10 17:37:04,206 - web_server - INFO - Successfully posted to sensor.unit_load_cost = 0.52
2023-07-10 17:37:04,221 - web_server - INFO - Successfully posted to sensor.unit_prod_price = 0.42
2023-07-10 17:38:00,048 - web_server - INFO - Setting up needed data
2023-07-10 17:38:00,050 - web_server - ERROR - ERROR: The passed data is either not a list or the length is not correct, length should be 48
2023-07-10 17:38:00,050 - web_server - ERROR - Passed type is <class 'list'> and length is 48
2023-07-10 17:38:00,052 - web_server - INFO - Retrieve hass get data method initiated...
2023-07-10 17:38:00,708 - web_server - INFO - Retrieving weather forecast data using method = scrapper
2023-07-10 17:38:02,110 - web_server - INFO - Retrieving data from hass for load forecast using method = naive
2023-07-10 17:38:02,110 - web_server - INFO - Retrieve hass get data method initiated...
2023-07-10 17:38:03,674 - web_server - INFO - >> Performing naive MPC optimization...
2023-07-10 17:38:03,674 - web_server - INFO - Performing naive MPC optimization
2023-07-10 17:38:03,693 - web_server - INFO - Perform an iteration of a naive MPC controller
2023-07-10 17:38:03,807 - web_server - INFO - Status: Infeasible
2023-07-10 17:38:03,807 - web_server - INFO - Total value of the Cost function = -3.6
2023-07-10 17:38:04,119 - web_server - INFO - Setting up needed data
2023-07-10 17:38:04,121 - web_server - INFO - >> Publishing data...
2023-07-10 17:38:04,122 - web_server - INFO - Publishing data to HASS instance
2023-07-10 17:38:04,141 - web_server - INFO - Successfully posted to sensor.p_pv_forecast = -0.75
2023-07-10 17:38:04,155 - web_server - INFO - Successfully posted to sensor.p_load_forecast = 977.36
2023-07-10 17:38:04,168 - web_server - INFO - Successfully posted to sensor.p_deferrable0 = 0.0
2023-07-10 17:38:04,183 - web_server - INFO - Successfully posted to sensor.p_deferrable1 = 0.0
2023-07-10 17:38:04,194 - web_server - INFO - Successfully posted to sensor.p_deferrable2 = 0.0
2023-07-10 17:38:04,203 - web_server - INFO - Successfully posted to sensor.p_deferrable3 = 0.0
2023-07-10 17:38:04,215 - web_server - INFO - Successfully posted to sensor.p_batt_forecast = -1949.47
2023-07-10 17:38:04,224 - web_server - INFO - Successfully posted to sensor.soc_batt_forecast = 10.0
2023-07-10 17:38:04,235 - web_server - INFO - Successfully posted to sensor.p_grid_forecast = 2927.58
2023-07-10 17:38:04,245 - web_server - INFO - Successfully posted to sensor.total_cost_fun_value = -3.6
2023-07-10 17:38:04,256 - web_server - INFO - Successfully posted to sensor.unit_load_cost = 0.52
2023-07-10 17:38:04,268 - web_server - INFO - Successfully posted to sensor.unit_prod_price = 0.42
EMHASS config:
hass_url: empty
long_lived_token: empty
costfun: profit
logging_level: INFO
optimization_time_step: 30
historic_days_to_retrieve: 2
method_ts_round: first
set_total_pv_sell: false
lp_solver: COIN_CMD
lp_solver_path: /usr/bin/cbc
set_nocharge_from_grid: false
set_nodischarge_to_grid: false
set_battery_dynamic: false
battery_dynamic_max: 1
battery_dynamic_min: -1
load_forecast_method: naive
sensor_power_photovoltaics: sensor.sonnenbatterie_84324_production_w
sensor_power_load_no_var_loads: sensor.house_power_consumption_less_deferrables
number_of_deferrable_loads: 4
list_nominal_power_of_deferrable_loads:
- nominal_power_of_deferrable_loads: 1500
- nominal_power_of_deferrable_loads: 1830
- nominal_power_of_deferrable_loads: 1000
- nominal_power_of_deferrable_loads: 3300
list_operating_hours_of_each_deferrable_load:
- operating_hours_of_each_deferrable_load: 2
list_peak_hours_periods_start_hours:
- peak_hours_periods_start_hours: "02:54"
- peak_hours_periods_start_hours: "02:00"
- peak_hours_periods_start_hours: "10:00"
- peak_hours_periods_start_hours: "03:00"
list_peak_hours_periods_end_hours:
- peak_hours_periods_end_hours: "15:24"
- peak_hours_periods_end_hours: "05:00"
- peak_hours_periods_end_hours: "20:00"
list_treat_deferrable_load_as_semi_cont:
- treat_deferrable_load_as_semi_cont: true
- treat_deferrable_load_as_semi_cont: false
load_peak_hours_cost: 0.1907
load_offpeak_hours_cost: 0.1419
photovoltaic_production_sell_price: 0.065
maximum_power_from_grid: 14490
list_pv_module_model:
- pv_module_model: CSUN_Eurasia_Energy_Systems_Industry_and_Trade_CSUN295_60M
list_pv_inverter_model:
- pv_inverter_model: Fronius_International_GmbH__Fronius_Primo_5_0_1_208_240__240V_
list_surface_tilt:
- surface_tilt: 21
list_surface_azimuth:
- surface_azimuth: 350
list_modules_per_string:
- modules_per_string: 17
list_strings_per_inverter:
- strings_per_inverter: 1
set_use_battery: true
battery_discharge_power_max: 3300
battery_charge_power_max: 3300
battery_discharge_efficiency: 0.95
battery_charge_efficiency: 0.95
battery_nominal_energy_capacity: 10000
battery_minimum_state_of_charge: 0.1
battery_maximum_state_of_charge: 0.9
battery_target_state_of_charge: 0.1
Don’t know what else might be wrong.
